| New Reply |
Time required for a mass to move below its equilibrium position to a point above it |
Share Thread | Thread Tools |
| Jun28-12, 10:18 PM | #1 |
![]() 2. Relevant equations t = 2[itex]\pi[/itex] [itex]\sqrt{}[/itex][itex]\frac{l}{g}[/itex] 3. The attempt at a solution for t t = 2[itex]\pi[/itex] [itex]\sqrt{}[/itex][itex]\frac{l1}{g}[/itex] t = 2[itex]\pi[/itex] [itex]\sqrt{}[/itex][itex]\frac{0.15m}{9.8 m/s^{2}}[/itex] t = 0.78 s t = 2[itex]\pi[/itex] [itex]\sqrt{}[/itex][itex]\frac{l2}{g}[/itex] t = 2[itex]\pi[/itex] [itex]\sqrt{}[/itex][itex]\frac{0.04m}{9.8 m/s^{2}}[/itex] t = 0.4 s total time t = 0.78 s + 0.4 s total time t = 1.18 s i changed the signs to positive because negatives dont have square root? |
| Jun28-12, 11:55 PM | #2 |
Recognitions:
You've misapplied the equation:
[tex]T=2\pi \sqrt{ \frac{l}{g} }[/tex]... is the equation to find the period T of a simple pendulum. The variable l is the distance from the pivot to the center of mass. So your working just figures out the natural period of pendulums with different length strings. (I wrote the equation out like that so you could see how to write equations in PF :) - hit the quote button to see how I did that.) It sounds like you need the equations of motion for a mass on a spring - something that looks like:[tex]mg-kx=m\ddot{x}[/tex]... the solution will be like:[tex]x(t)=A \cos(\omega t) + B[/tex]Since you are not provided with details for the system - you'll be looking at a ratio method or an approximation for very small distances. eg. is the speed close to the equilibrium point very nearly constant? Of course there may have been data that you have not given us :) |
| New Reply |
| Thread Tools | |
Similar Threads for: Time required for a mass to move below its equilibrium position to a point above it
| Torque required to lift a given mass around a point. | Introductory Physics Homework | 3 | ||
| HELP! Find the mass in this inclined pulley system, required to move the 2 masses | Introductory Physics Homework | 4 | ||
| How to calculate time for ticker tape to move from a point to another point? | Introductory Physics Homework | 7 | ||
| Force Required to move a 63.5 kg mass. | Introductory Physics Homework | 2 | ||
| Time required to move object | Introductory Physics Homework | 3 | ||
