| New Reply |
rotation and translation of an object.. |
Share Thread | Thread Tools |
| Jun29-12, 03:44 PM | #1 |
Hello Forum,
if a force is applied to an object along a direction that passes through the center of mass, the object will translate without rotation. If the force acts along a line that does not pass through the CM, will the object both rotate and translate? Where and how does the force need to applied to cause the object to only rotate and not translate? I am assuming the object is not constrained but free to move in any direction... To obtain translation does the force need to always have a component along a direction that goes through the center of mass? thanks, fisico30 |
| Jun29-12, 04:06 PM | #2 |
| Jun29-12, 08:21 PM | #3 |
"Two parallel or somewhat parallel pokes off-centre could sum up to translational movement with no rotational movment...."
True. So the translation is not only caused by forces directed through the center of mass. The net force, sum of the two force, goes through the CM, does it? |
| Jun29-12, 10:34 PM | #4 |
Recognitions:
| Jun30-12, 09:06 AM | #5 |
Thank you.
So, to be general, maybe we should discuss the possibility (or lack of it) of translation of rotation in terms of net torque about the center of mass and net force about the center of mass: 1) zero net torque about CM implies no rotation of the object, even if translation may present. In the example of two parallel forces with same direction, applied on either side of the CM at equal distance, the net torque is zero. The net force is not zero, but does it really act through the center of mass? How do we prove that? 2) zero net force about the CM implies no translation of the object, but possibly rotation (a couple of forces) thanks fisico30 |
| Jun30-12, 06:54 PM | #6 |
Recognitions:
| Jun30-12, 08:24 PM | #7 |
Recognitions:
Sure, sometimes you can resolve a velocity into components, find the KE corresponding to each component, but you have to be careful what you mean by "velocity" if the body is rotatinng! Don't confuse energy and momentum (which is a vector). They are two different things. |
| Jun30-12, 08:43 PM | #8 |
Hello Haruspex,
The net force is not zero, but does it really act through the center of mass? How do we prove that? You mention from the fact the rotation is absent. That means that the net torque is zero. But, vectorwise, there must be a net force through the CM due to the two forces... How do we prove that there is going to be a net force? How does it relate to those two forces causing torques that cancel each other? fisico30 |
| Jul1-12, 12:33 AM | #9 |
| Jul1-12, 03:34 AM | #10 |
Mentor
How to prove this? Two ways. One is via Newton's laws, the other via the conservation laws. Every undergraduate physics classical mechanics text will proves this in one of the opening chapters of the text. |
| Jul1-12, 11:21 AM | #11 |
| New Reply |
| Thread Tools | |
Similar Threads for: rotation and translation of an object..
| Rotation v. Translation? | Introductory Physics Homework | 2 | ||
| Rotation vs. Translation | General Physics | 4 | ||
| translation and rotation | Introductory Physics Homework | 8 | ||
| translation/rotation | Introductory Physics Homework | 17 | ||
| Translation/Rotation | Differential Geometry | 2 | ||
