Minimum Velocity for Satellite Escape from Earth's Attraction
  • Context: Undergrad
  • Thread starter Thread starter josephcollins
    Minimum Velocity
The discussion centers on calculating the minimum velocity required for the satellite Meteosat to escape Earth's gravitational attraction. Participants explore the theoretical framework and mathematical formulations related to gravitational potential energy and kinetic energy, specifically in the context of orbital mechanics.
  • One participant proposes that the total energy needed for escape is given by GMm/2(R), where M is the mass of Earth, m is the mass of the satellite, and R is the orbit.
  • Another participant calculates the escape velocity using the formula v = sqrt(2GM/R) and arrives at a different value of 4349 m/s, questioning the initial formulation.
  • Some participants discuss the distinction between potential energy and total energy, with one asserting that the total energy includes both kinetic and potential energy.
  • There is a suggestion that the escape velocity should be calculated based on the condition that the total energy at infinity is zero, leading to a different interpretation of the required velocity.
  • Participants express uncertainty about the correct interpretation of energy equations and whether the initial calculations represent the escape velocity or the additional velocity required to escape.
  • One participant emphasizes the importance of including the negative sign in the potential energy expression and clarifies that the question asks for escape velocity rather than additional velocity.
  • Another participant points out that the calculations provided do not yield the correct additional velocity required for escape, as highlighted in a later edit.
Participants do not reach a consensus on the correct method for calculating the escape velocity, with multiple competing views and interpretations of the energy equations presented throughout the discussion.
There are unresolved assumptions regarding the definitions of kinetic and potential energy in the context of orbital mechanics, as well as the implications of different formulations for escape velocity versus additional velocity required.
josephcollins
Hi ppl, could someone just clarify this for me
i need to find the minimum velocity that the satellite meteosat (time period is 23h56min and altitude is 35800km + radius of earth(6370km)) must be given to escape from the force of attraction of the Earth.
I started by saying that the total energy needed to effect this is GMm/2(R) where M is mass of earth, m is mass of satellite and R is orbit. Then I equated this to mv^2/2
My final answer was 3078ms^-1 Could someone verify my working or at least show me where I made an error if there is one?
Thanks, Joe
Yes,your answer is correct,as well as the method to get it...
Daniel.
Why 2(R) in the denominator? I think it should be:
[tex]\frac{1}{2}v^2 = \frac{GM}{R}[/tex]
[tex]v = \sqrt{2GM/R}[/tex]
[tex]v = (2*6.67e(-11)*5.98e24/4.217e7)^.5 = 4349 m/sec.[/tex]
AM
AM
I think so too.
The reason I took 2r as the denominator is that GMm/2r is the total energy of the satellite at that position in orbit, whereas GMm/r is just the potential...
Is this correct?
Yes,my guess is that u were right in the first place,as the satellite certainly has KE,not only PE.If my memory doesn't cheat me,it is your formula...
However,i may be wrong...
We need some other opinion.
Daniel.
Is this correct?
Can you explain why you think the satelite's energy is -GMm/2r ? Does this include it's kinetic energy?
Yes.It's the only possible reason.
Daniel.
Assuming circular motin the satelites potential energy is:
[tex]-G\frac{Mm}{r}[/tex]
It's kinetic energy is:
[tex]\frac{1}{2}m\frac{(2 \pi r)^2}{T^2}[/tex].
Keplers law gives
[tex]T^2=\frac{(2 \pi r)^2 r}{GM}[/tex]
so the kinetic energy can be written
[tex]G \frac{Mm}{2r}[/tex].
The total energy is kinetic plus potential:
[tex]-G\frac{Mm}{2r}[/tex], so you're correct.
At infinity it's total energy wil be zero, so you'll have to add:
[tex]\frac{1}{2}mv^2 = G\frac{Mm}{2r}[/tex].
So the escape velocity is:
[tex]v_{esc}=\sqrt{G\frac{M}{r}}=3075ms^{-1}[/tex]
So you're totally right.
EDIT: As Andrew Mason pointed out, you (and I) calculated the extra velocity required to escape, not the escape velocity...
Is this correct?
Not quite. It is -GMm/r. It is important to include the - sign in the potential.
The question asks for the minimum velocity needed to escape so it doesn't matter what velocity it has while orbiting. But if you were asked what the additional speed is required, it would be the difference between the escape velocity and the orbital velocity. You calculated the orbital velocity, not the escape velocity.
ie. The energy of the satellite in orbit is:
(1)[tex]E_{orbit} = KE + PE = \frac{1}{2}mv^2 - \frac{GMm}{r}[/tex]
Since:
[tex]\frac{mv^2}{r} = F = \frac{GMm}{r^2}[/tex]
(1) reduces to:
[tex]E_{orbit} = \frac{1}{2}\frac{GMm}{r} - \frac{GMm}{r}[/tex]
[tex]E_{orbit} = - \frac{1}{2}\frac{GMm}{r}[/tex]
Since the condition for escape is that KE + PE = 0, the kinetic energy needed for escape is twice the orbital kinetic energy. This requires increasing the kinetic energy by factor of 2 or its speed by [itex]\sqrt{2}[/itex]
AM
Since the question asks for the escape velocity rather than the root sqaure excess velocity, you must use R and not 2R. I concur with AM.
[tex]KE(in) + PE(in) = E(fin) = 0[/tex]
[tex]\frac{1}{2}mv_{esc}^2 - \frac{GMm}{R} = 0[/tex]
That's all there is to it.
If you add the existing KE to the PE to get _GMm/2R, you are then only finding the extra KE required. This is not what's asked.
How did you go from additional KE to escape velocity ?
Okay,Gokul,which part didn't u understand??This one:
Please explain to me how would you keep a geostationary satellite in orbit 42000Km (from the Earth's center) MOTIONLESS... :rolleyes:
Daniel.
Read the EDIT one line below...
Not exactly. The additional velocity is [itex](\sqrt{2}-1) \times 3075 = 1274 m/s.[/itex]
AM
No one said it is motionless. Its orbital speed is 3075 m/s. It needs to have a speed of 4349 m/s (or twice the kinetic energy than 3075 m/s) in order to escape.
AM
dexter, if you see a mistake in my post, point it out. And take it easy with the large fonts !
Your calculation does not even find the correct additional velocity required, as AM pointed out above. It only calculates what I refer to as the "root excess square velocity", which is quite a meaningless number for the given problem.
  • · Replies 43 ·
  • · Replies 17 ·
