| Thread Closed |
Kinematics Acceleration Equation help please |
Share Thread | Thread Tools |
| Jun30-12, 01:19 AM | #1 |
A car accelerates at 3 meters squared from rest for 10s. How far does it travel?
a = 3 meters squared v1 = 0? v2 = ? Δd = ? Δt = 10s Why is velocity 1, 0? Why is delta t 10 seconds? |
| Jun30-12, 03:18 AM | #2 |
hi jbeannie05! welcome to pf!
![]() ∆t is the time from start to finish: since it says it accelerates "for 10s", that means ∆t = 10 now apply the usual constant acceleration equations … what do you get?(btw, it's not 3 metres squared, it 3 metres per second-squared, 3 ms-2) |
| Jun30-12, 03:25 AM | #3 |
v1 is given to you as 0 because the car starts from rest
Δt is also given to you: the car accelerates during 10s With this you must have seen the formulas to deduce v2 (the velocity after 10s) and the total distance travelled. |
| Jun30-12, 08:40 AM | #4 |
Δd=v1Δt+aΔt^2
This should answer your question. |
| Jun30-12, 10:38 AM | #5 |
| Jun30-12, 11:59 AM | #6 |
d=v1t+.5at^2 |
| Jun30-12, 08:54 PM | #7 |
A car accelerates at 3 metres per second-squared from rest for 10s. How far does it travel?
a = 3 metres per second-squared v1 = 0? v2 = ? Δd = ? Δt = 10s So, a is the acceleration, which is at 3 metres per second-squared, the initial velocity is 0, because the question says it starts "from rest", Δt, this will determine the interval of time used in determining the velocity, I think, not sure, and v2 and Δd is unknown. Am I right so far? |
| Jun30-12, 09:02 PM | #8 |
Start with distance travel=average velocity × time
Here in the problem you have to find average velocity. You are given value of acceleration which is assumed to be constant. From this value you can find average velocity. |
| Jun30-12, 09:03 PM | #9 |
you are right on so far
| Jun30-12, 10:30 PM | #10 |
a = 3 metres per second-squared (acceleration) v1 = 0? (initial velocity) v2 = ? (final velocity) Δd = ? (displacement) how far does something travel? Δt = 10s (interval) time So, a is the acceleration, which is at 3 metres per second-squared, the initial velocity is 0, because the question says it starts "from rest", Δt, this will determine the interval of time used in determining the velocity. v2 and Δd is unknown. Am I right so far? |
| Jun30-12, 11:35 PM | #11 |
I'm not sure what you know about Kinematics, for a start one dimension.
| Jun30-12, 11:45 PM | #12 |
one dimension?
| Jul1-12, 02:19 AM | #13 |
hi jbeannie05!
![]() (just got up )![]() now look up the standard constant acceleration equations, and apply one of them
| Jul1-12, 08:59 PM | #14 |
a = 3 metres per second-squared (acceleration) v1 = 0? (initial velocity) v2 = ? (final velocity) Δd = ? (displacement) how far does something travel? Δt = 10s (interval) time So, a is the acceleration, which is at 3 metres per second-squared, the initial velocity is 0, because the question says it starts "from rest", Δt, this will determine the interval of time used in determining the velocity. v2 and Δd is unknown. Δd = v1Δt + one half 2 squared Δd = 0Δt + one half 3 metres per second-squared 10s 2 squared Is that the right equation to use? |
| Jul1-12, 09:20 PM | #15 |
| Jul1-12, 09:21 PM | #16 |
| Jul1-12, 10:56 PM | #17 |
a = 3 metres per second-squared (acceleration) v1 = 0? (initial velocity) v2 = ? (final velocity) Δd = ? is how far(vector) it is from the origin. Δt = 10s (interval) time So, a is the acceleration, which is at 3 metres per second-squared, the initial velocity is 0, because the question says it starts "from rest", Δt, this will determine the interval of time used in determining the velocity. v2 and Δd is unknown. Δd = v1Δt + ½at^2 Δd = (0)(Δt) + ½(3m/s^2)(10s)^2 Is that the right equation to use? |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Kinematics Acceleration Equation help please
| Free-Fall Kinematics equation- how to find acceleration when just given initial speed | Introductory Physics Homework | 2 | ||
| Kinematics - which equation to use in kinematics problems? | Introductory Physics Homework | 14 | ||
| Kinematics-Acceleration | Introductory Physics Homework | 2 | ||
| Help with Kinematics and Acceleration | Introductory Physics Homework | 7 | ||
| Equation of Kinematics for Constant Acceleration | Introductory Physics Homework | 3 | ||
