New Reply
Calculating coefficient of friction given m, applied force, and a
Share Thread Thread Tools
Jun30-12, 08:57 PM   #1
From http://library.thinkquest.org/10796/index.html (#6)
A book has a mass of 400 g. When you slided the book against the floor with 5 N, it accelerated at the rate of -1.5 m/s2. What would the coefficient of friction between the book and the floor be?
[tex]g=9.80m/s^2[/tex]
2. Relevant equations
[tex]F=ma[/tex]
[tex]F_f=\mu F_N[/tex]
[tex]F_N=mg[/tex] (The site actually states the normal force to be equal to negative mass times gravitational acceleration, but with a negative value for gravitational acceleration. I'm going with Wikipedia, though.)
[tex]n\textrm{g}=\frac{n}{1000}\textrm{kg}[/tex]
3. The attempt at a solution
First off, I'd like to say that this site was made by high school seniors, so I'm put in the uncomfortable position of not being able to readily accept everything that's there.
Next, why is the applied force positive but the acceleration negative? I'll just assume that that was a mistake and that the applied force should actually be -5N.
[tex]-5\textrm{N}+F_f=F\implies F_f=F+5\textrm{N}[/tex]
(Right? It seems right to me....)
[tex]F=0.4\textrm{kg} \times -1.5\textrm{m/s}^2[/tex]
[tex]F_f=\mu \times 0.4\textrm{kg} \times 9.80 \textrm{m/s}^2[/tex]
[tex]\mu=\frac{F_f}{0.4\textrm{kg} \times 9.80 \textrm{m/s}^2}=\frac{0.4\textrm{kg}\times -1.5\textrm{m/s}^2+5\textrm{N}}{0.4\textrm{kg} \times 9.80 \textrm{m/s}^2}[/tex]
[tex]\mu=1.122[/tex]
I get the same answer when I keep the applied force positive, make the acceleration positive, and use [tex]5\textrm{N}-F_f=F\implies F_f=5\textrm{N}-F.[/tex]
Yet, the site's answer is 0.15.
I even tried using a positive applied force with a negative acceleration (pretending that friction could make an object go in the opposite direction of the applied force).
[tex]5\textrm{N}-F_f=F\implies F_f=5\textrm{N}-F[/tex]
[tex]\mu=\frac{F_f}{0.4\textrm{kg} \times 9.80 \textrm{m/s}^2}=\frac{5\textrm{N}-0.4\textrm{kg}\times -1.5\textrm{m/s}^2}{0.4\textrm{kg} \times 9.80 \textrm{m/s}^2}[/tex]
[tex]\mu=1.429[/tex]
Then I realized that, using 400 instead of 0.4, you get -0.152, -0.152, and 0.154, respectively, for the three attempts described above.
Somebody, please, what is going on here?? I'd really appreciate some help, and it'd be great if you simply told me that the site was really wrong.
Thank you!!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Jun30-12, 09:17 PM   #2
From data given, maximum frictional force=mg<5N(applied force)
The direction of acceleration should be positive.
Jun30-12, 09:57 PM   #3
Recognitions:
Homework Helper Homework Help
As aziziwi states, the acceleration given in the problem should be in the same direction as the applied force ... so it should have the same sign.
The site says that the normal force is -mg is correct if g=-9.8m.s-2 ... i.e. the normal force is equal and opposite to gravity, which you'd normally give as mg. Take care interpreting equations ... a minus sign in front of a thingy does not have to imply that you take the negative of that thingy.
But the site looks somewhat confused to me. It says at the top that this is by students for students, and I see no way to edit it or submit corrections, so I'm not really all that surprised.
Jun30-12, 10:06 PM   #4
Recognitions:
Gold Membership Gold Member
Site is pretty bad. I'm surprised it is not first proofread and checked by a teacher before posting.
New Reply
Tags
acceleration, applied, coefficient, friction, mass
Thread Tools
Similar Threads for: Calculating coefficient of friction given m, applied force, and a
Thread Forum Replies
Coefficient of Friction when applied force is not horizontal to surface? Introductory Physics Homework 3
Calculating Static Friction and the Coefficient of Friction Introductory Physics Homework 1
Find the mass of object knowing the applied force and coefficient of friction Introductory Physics Homework 3
Calculating Force at an angle with kinetic friction coefficient Introductory Physics Homework 11
Finding Acceleration from Friction Coefficient and Force Applied Introductory Physics Homework 6
