Calculate Thickness of Copper Plate | Density and Mass Formula
  • Thread starter Thread starter runner1738
    Density Mass
The problem involves calculating the thickness of a copper plate given its mass, radius, and density. The subject area pertains to concepts of density, volume, and geometric properties of circular plates.
  • Exploratory, Mathematical reasoning
  • Participants discuss the relationship between mass, density, and volume, with one participant questioning how thickness is derived from these values. Another suggests using the area of the plate to find the volume and subsequently the height (thickness).
The discussion has progressed with participants exploring the necessary calculations to find the thickness. One participant confirms understanding after receiving guidance on the relationship between mass, density, and volume.
Participants are working within the constraints of the given mass, density, and area, with no additional information provided about the problem setup or assumptions.
runner1738
Aflat circular plate of copper has a radius of .175m and a mass of 96.1 kg. What is the thickness of the plate? Answer in units of m.
I know that the density of copper is 8.92(10^3kg/m^3) and the area of the plate is .0962m^2, and i don't see how the thickness is related with the mass. maybe mass/density = volume or something like that
Since you have the area of the plate, think about what volume is for the circular plate. Area of the base X height of the plate. you are trying to solve for the height of the plate.
Density = mass/volume
You are given density and mass, so you can solve for volume. By cancelling unit, you are given a volume in m^3
so your saying its 96.1(mass)/8.92(density)=volume then volume/area gives me my answer?
yep i got it right thank you
  • · Replies 26 ·
