How Can We Design the Most Efficient Micro-Wind Turbine Propeller?
The discussion revolves around designing an efficient propeller for a micro-wind turbine intended to rotate at low air velocities, specifically around 3mph, which is the typical walking speed. Participants explore various design considerations, including propeller size, blade shape, pitch, and material properties, while seeking to optimize for low-speed rotation without relying on higher wind speeds.
  • One participant suggests that the proposed design of the propeller, with a diameter between 2”-4” and a focus on easy rotational start, is on the right track but does not provide specific feedback on blade shape versus efficiency.
  • Another participant expresses concern about the feasibility of achieving rotation at a 3mph activation speed, implying that this requirement may be overly ambitious.
  • A different viewpoint emphasizes the importance of blade weight and internal resistance of the motor over blade shape, referencing the lightweight nature of pinwheels as a potential advantage.
  • One participant recommends using a tool called Javaprop, which employs blade element theory to aid in propeller design, providing a mathematical framework for estimating thrust based on various aerodynamic factors.
Participants generally agree that the design considerations are important, but there is no consensus on the optimal blade shape or the feasibility of the 3mph activation speed. Multiple competing views on the significance of different design factors remain unresolved.
Participants have not fully explored the assumptions behind the 3mph activation speed or the specific aerodynamic characteristics required for the propeller design. The discussion also lacks detailed mathematical validation of the proposed designs.
This discussion may be useful for individuals interested in low-speed aerodynamics, micro-wind turbine design, and practical applications of blade element theory in propeller design.
edgar360
Hi everyone!
I would be so happy if someone could help my little brother and I answer a question for a science project that we have researched ineffectively for hours. We hope to design the most efficient propeller for micro-wind turbine. The purpose of this propeller is to naturally rotate when held in the air by a walking person. Thus, disregarding wind, a mere 3mph (walking speed) oncoming air velocity or less must instigate rotation. Below are our design assumptions for such a propeller:
Propeller between 2”-4” in diameter.
Designed for easy rotational start rather than fast rotation once turning.
Thus, large surface area on blades, accepting the additional weight.
Blades pitched very shallow, and blades as thin as possible.
Propeller mounted on thinnest bar possible (1/16”) more efficiency.
How correct are we about the above? We think the best propeller design would be very similar to that of the HY mini wind-turbine charger (pictures below).
The HY propeller is designed to generate power at a 9mph velocity, whereas ours only needs to rotate freely but at a 3mph velocity. What changes need to be made to the HY propeller design in order to customize it for our purpose? A difference in blade shape or pitch? Please be as descriptive as possible or even better, draw it! We’re determined to win this science contest! (we are not interested in pinwheels due to their looks or anemometers due to their shape)
Your propellor seems to be on the right track, unfortunately I can't give any useful feedback on the blade shape vs. efficiency. I can tell you that most any blade design will spin with a low enough frictional coefficient on the shaft; if you use super-smooth bearings and low viscosity oil you should be good to go.
My concern here is with the 3mph activation speed. That's asking a lot.
It looks like your on the right track.
In this case, more important than blade shape may be blade weight and internal resistance of the motor. Notice that pinwheels are extremely light (as they are made of paper-like products) and have a large blade diameter relative to the hub. A tool which uses blade element theory to design propellers is Javaprop:
<http://www.mh-aerotools.de/airfoils/javaprop.htm>
This tool will provide you with first approximation quality results. This is because the idea behind blade element theory is that each propeller can be divide into...elements! with the thrust generated by each element approximated by:
[itex]T_{i} = CL_{i}(\alpha_{i},M_{i},RE_{i}) / (1/2 \rho V_{i}^2 S_{i})[/itex]
Where:
α = angle of attack
M = mach number
RE = reynolds number
CL = lift coefficient as a function of the above three variables
rho = density of air
S = element surface area
The sum of the above equation is the net thrust.
  • · Replies 41 ·
23K
  • · Replies 69 ·
18K
  • · Replies 30 ·
