Maximum distance of charge from current carrying wire
The discussion focuses on determining the maximum distance of a charged particle from an infinitely long current-carrying wire. Two methods are proposed for solving the problem: one involves solving differential equations based on forces in the x and y axes, while the other utilizes integration of magnetic field strips. The second method incorrectly integrates sin(dθ) instead of sin(θ), leading to an erroneous result. The correct approach, as confirmed by participants, is to integrate sin(θ) dθ, which aligns with the first method's findings.
  • Understanding of electromagnetic theory, specifically magnetic fields around current-carrying wires.
  • Familiarity with differential equations and their applications in physics.
  • Knowledge of integration techniques in calculus.
  • Concept of charged particle motion in magnetic fields.
  • Study the derivation of magnetic fields around infinite current-carrying wires using Ampère's Law.
  • Learn about the Lorentz force and its impact on charged particles in magnetic fields.
  • Explore advanced integration techniques, particularly in the context of physics problems.
  • Investigate the application of differential equations in modeling particle motion in electromagnetic fields.
Physics students, educators, and researchers interested in electromagnetism and particle dynamics in magnetic fields.
Algren
Lets have a charged particle at a distance x at the beginning with velocity v away from a current carrying wire with current I. So, what will be the maximum distance of the particle from the wire? (only consider magnetic field)(wire is of infinite length)
There are two ways of solving the problem.
One is: Find forces in x and y-axis at a given time, get diff. equations, and solve em, and integrate tem.
Another is: We consider strips of magnetic field with 'dx' thickness, and integrate the deviation 'dθ' of the charged particle over all these strips from 0 to ∏/2. But in this case, i end up integrating sin(dθ). If i integrate sin(θ) dθ instead, i get the correct answer as so derived from the first way.
But i wanted to ask, is there any problem with the logic of the second way?
How do you end up with integrating sin(dθ) ? You should be integrating sinθ w.r.t θ. Show me your work. You should have done any careless or conceptual mistake. Otherwise you shouldn't have arrived at such strange result.
Please post your second method here (with details and steps inclusive).
  • Sticky
  • · Replies 0 ·
  • · Replies 61 ·
  • · Replies 27 ·
