New Reply
Tunnels through the center of planet, oscillations
Share Thread Thread Tools
Jul2-12, 06:37 PM   #1
Hi all,
I know that if you drill a hole from one side of the planet to the other, through the planet's center, that a particle dropped in this tunnel will oscillate back and forth forever, like a mass on a spring, with the restoring force given by gravity.
What if the tunnel forms a chord that goes from point A, (say New York City) to point B (say London) but does NOT go through the Earth's center. If I drop a particle in this new tunnel, will the particle also undergo simple harmonic motion back and forth forever?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> A quantum simulator for magnetic materials
>> Atomic-scale investigations solve key puzzle of LED efficiency
>> Error sought & found: State-of-the-art measurement technique optimised
Jul2-12, 07:08 PM   #2
Mentor
Quote by Albertgauss View Post
Sure. (Assuming the usual idealizations of uniform density and no friction.) Set up the math to find the restoring force, and you'll see things work out exactly the same in both cases.
Jul2-12, 07:10 PM   #3
It would fall into the lower wall of the pit and sooner or later stop because of friction, probably at the lowest point of the tunnel. If you could somehow remove all friction though, and consider only the component of the gravitational force that is parallel to the tunnel, then yes, it would oscillate in harmonic motion. Provided your planet's density is the same everywhere.
Jul2-12, 07:15 PM   #4
Recognitions:
Gold Membership Gold Member
I think we did this one recently.
Jul2-12, 07:21 PM   #5
Mentor
Quote by epenguin View Post
It's a standard freshman exercise.
Jul2-12, 08:30 PM   #6
Hi all,
I got it. Thanks! That's what I needed to know. Sorry if this was done recently, I couldn't find it when I searched.
New Reply
Thread Tools
Similar Threads for: Tunnels through the center of planet, oscillations
Thread Forum Replies
Pressure at center of planet General Astronomy 7
SR effects at the center of a planet Special & General Relativity 1
GR - time dialation at center of a planet Special & General Relativity 4
Pressure at the center of a planet Introductory Physics Homework 2
Pressure at center of earth (or any planet) Introductory Physics Homework 0
