Computing arc length in Poincare disk model of hyperbolic space
The discussion revolves around computing arc lengths in the Poincare disk model of hyperbolic space, focusing on the hyperbolic metric and its application to distance calculations. Participants explore the implications of the metric formula and the necessary steps to derive arc lengths, including parametrization and the use of Christoffel symbols.
  • One participant expresses confusion about the meaning of the hyperbolic metric ds^2 and how to compute distances and arc lengths from it, proposing an initial formula for arc length.
  • Another participant points out that the expression for the metric cannot be simplified as suggested and emphasizes the need for proper parametrization and the correct definition of arc length involving the metric tensor g.
  • A subsequent reply introduces the geodesic equation as a method to find the trajectory needed for arc length calculation.
  • Another participant questions the necessity of computing Christoffel symbols and seeks a more straightforward method to derive arc length from ds^2.
  • One participant clarifies that g_{\mu\nu} represents the metric of the space and provides details on how to express it in the context of the problem, along with the method to compute the Christoffel symbols.
Participants express differing views on the approach to calculating arc lengths, with some advocating for a detailed method involving Christoffel symbols and others seeking a simpler solution. The discussion remains unresolved regarding the best approach to take.
There are limitations in the discussion regarding the assumptions made about the metric and the integration process, as well as the dependence on specific parametrizations and the definitions of terms like g_{\mu\nu} and the Christoffel symbols.
owlpride
I am reading Thurston's book on the Geometry and Topology of 3-manifolds, and he describes the metric in the Poincare disk model of hyperbolic space as follows:
... the following formula for the hyperbolic metric ds^2 as a function of the Euclidean metric x^2:
[tex]ds^2 = \frac{4}{(1-r^2)^2} dx^2[/tex]
I don't understand how what ds^2 means or how to use this formula to compute distances and arc lengths. A naive guess is that the arc length should be given by
[tex]s = \int_a^b \sqrt{ds^2}[/tex]
but that doesn't seem to give me the correct answer. For example, take a point with Euclidean distance r from the origin. What is its distance in the hyperbolic metric?
I know that the distance should be the arc length of the straight line connecting 0 to x, since the straight line through the origin is a geodesic in the hyperbolic metric. My guess would give me an arc length of
[tex]s = \int_0^r \frac{2}{1-x^2} dx = 2 arctanh(r)[/tex]
However, another website claims that the answer should be log(1+r)/log(1-r).
Can someone help?
There are some mistakes in your claims.
First of all the expression for the metric cannot be "square-rooted" so easily, in fact
[tex]\mathrm{d}x^2 = \mathrm{d}x^i\mathrm{d}x_i = \mathrm{d}x^2+\mathrm{d}y^2[/tex]
then the definition of arc length is the integral of the velocity along the curve (i.e. the trajectory), defined as (be careful there can be a sign under the square root, it depends on your convention):
[tex]L = \int^b_a \sqrt{\frac{\mathrm{d}x^{\mu}}{\mathrm{d}t} \frac{\mathrm{d}x^{\nu}}{\mathrm{d}t} g_{\mu\nu}} \mathrm{d}t[/tex]
with [tex]x^{\mu} = \left\{x,y\right\}[/tex] .
So the first thing you have to do is to choose a parametrization of your coordinates and then proceed to compute the integral. Note also that
[tex]r^2 = x^2 + y^2[/tex]
Let me know if you get the right result! ;)
Oh, I forgot to tell you that you can get [tex]x^{\mu}\left(t\right)[/tex] solving the geodesic equation
[tex]\frac{\mathrm{d}^2 x^{\mu}}{\mathrm{d} t^2} + \Gamma^{\mu}_{\nu\rho}\frac{\mathrm{d} x^{\nu}}{\mathrm{d} t}\frac{\mathrm{d} x^{\rho}}{\mathrm{d} t} = 0[/tex]
Thanks, but I'm not really sure what to do with the information you just gave me. What does [tex]g_{\mu\nu}[/tex] mean? Do I really need to compute the Christoffel symbols? If yes, how would I compute them from "ds^2"?
All I care about right now is the simplest way to get from "ds^2" to arc length. If I don't absolutely need to compute all the other crap, I'd rather not.
[tex]g_{\mu\nu}[/tex] is the metric of your space. In fact, [tex]\mathrm{d} s^2 = g_{\mu\nu} \mathrm{d} x^{\mu} \mathrm{d} x^{\nu}[/tex]
In your case g is a square 2x2 diagonal matrix with the function [tex]\frac{4}{\left(1-r^2\right)^2}[/tex] as each element. You can also write [tex]g_{\mu\nu} = \frac{4}{\left(1-r^2\right)^2} \delta_{\mu\nu}[/tex]. This is how I'd solve the problem, I don't know if there is a faster way! =)
The Christoffel symbols are easily computed from g using the usual form for the Levi Civita connection symbols:
[tex]\Gamma^{\mu}_{\nu\rho}= \frac{1}{2} g^{\mu\lambda}\left(\partial_{\nu}g_{\lambda \rho} + \partial_{\rho}g_{\nu \lambda } - \partial_{\lambda}g_{\nu \rho}\right)[/tex]
