| New Reply |
Modelling/Simulation of a Linear BLDC motor |
Share Thread | Thread Tools |
| Jul5-12, 04:06 AM | #1 |
Hi,
I'm trying to implement a complete model of ha Faulhaber Linear BLDC motor with the purpose of derriving a controller suitable for a microcontroller ouputing a PWM voltage. The motor is supposed to move a given load to follow a reference signal. Accordingly to http://www.physicsforums.com/showthread.php?t=591062 it might be okay to model the motor as a common brushed DC motor Do you have any tips? I have tryed to follow the master thesis by Stefan Baldursson (http://webfiles.portal.chalmers.se/e...nStefanMSc.pdf) with out success. (This motor is however not a linear BLDC) Could it be suitable to use a system identification method instead of modelling as proposed in that thesis? the identificatin method would mean that I meassure input vs output of the motor (should it be with or without load?) Or is the "brushed DC motor"-solution mentioned above a suitable approach? |
| Jul6-12, 12:06 PM | #2 |
to clarify, you have a motor moving a load following a reference signal...
1) mechanical system: how is the motor connected to load? how does it move through space? what is its mass? 2) motor system: (the equ's from the papers) how does voltage and current affect the motor in terms of speed and/ or torque? 3) control system: what does the voltage reference signal represent? Speed, torque, or position? What voltage or current will you apply in a certain sequence to mimic some movement. |
| New Reply |
| Tags |
| bldc, matlab, simulink |
| Thread Tools | |
Similar Threads for: Modelling/Simulation of a Linear BLDC motor
| Interpreting BLDC motor spec sheet | Electrical Engineering | 0 | ||
| bldc motor | Engineering Systems & Design | 4 | ||
| BLDC Motor - Operation with Phase Loss | Electrical Engineering | 3 | ||
| BLDC motor load performance | Mechanical Engineering | 2 | ||
| Regarding Transferfunction of BLDC Motor | Electrical Engineering | 0 | ||
