Shaving Cream in a Vacuum project
  • Thread starter Thread starter Bissli
    Project Vacuum
The forum discussion centers on an IB Group 4 science project investigating the expandability of various brands and types of shaving creams in a vacuum bell jar. The experiment aims to correlate the expandability of shaving creams with user satisfaction after testing. Key insights reveal that shaving cream is a gas dissolved in a liquid, and its expansion is influenced by pressure changes, similar to the behavior of marshmallows in a vacuum. The discussion also raises questions about the functional properties of shaving cream during shaving, such as lubrication and cushioning.
  • Understanding of gas laws, particularly how pressure affects gas solubility
  • Familiarity with vacuum chamber experiments and their effects on materials
  • Basic knowledge of the composition and function of shaving creams
  • Experience with scientific experimentation and data collection methods
  • Research the chemical composition of different shaving creams and their effects on expandability
  • Explore the principles of gas solubility and pressure using real-world examples
  • Investigate the role of lubricants in shaving products and their impact on user experience
  • Conduct comparative experiments with other products, such as whipped cream or foams, in vacuum conditions
This discussion is beneficial for students conducting scientific experiments, researchers interested in material properties under pressure, and anyone exploring the chemistry behind personal care products like shaving creams.
Bissli
Four our huge IB Group 4 science project, we are doing an experiment where we are placing different brands/types of shaving creams into a vacuum bell jar and measuring the expandability of each cream. Then we are having men test out the shaving creams, and seeing if the expandability of the shaving creams relates in any way to user satisfaction.
Now, this is a random idea we thought of, but I'm having trouble finding out what in shaving cream causes it to expand...air trapped between molecules? but does anyone know what difference between shaving creams could cause one to expand more than the other? and what exactly does shaving cream do? does it provide a cushion between razor and skin?
thanks to any comments!
shaving cream is a gas that is dissolved in a liquid.
as you know, when you increase the pressure, gasses contract, and you can dissolve more gas into a liquid. Inside a can of shaving cream, you have a lot of shaving cream packed in under high pressure, meaning that a lot of gas (air probably, I don't exactly know what the gas is), is dissolved into the liquid, when you push the button and it shoots out, it exands, this is due to the relatively low pressure outside the can compared to the pressure inside the can, so some of the gas exans and excapes, this caused the shaving cream to expand.
The same thing happens when you put shaving cream from normal "room" pressure into a vacuum chamber, most/all of the gas excapes and expands the shaving cream a lot. something similar can be seen by putting a marshmellow inside a vacuum chamber, a marshmellow is a gas dissolved in a solid, the marshmelow will temporarily expand when all the gasses are rushing out, but then it colapses under its own weight because there is nothing to hold it up.
Thanks for the help Mrjeffy,
I was also wondering if anyone knew exactly what shaving cream does when you shave? lubricant? cushion?
