Prove that [itex]a[/itex] is not an integer
  • Context: Graduate
  • Thread starter Thread starter S.Iyengar
    Integer
The discussion revolves around proving that a specific logarithmic expression, defined in terms of non-zero positive integers and a prime number, does not yield an integer value. The scope includes mathematical reasoning and exploration of conditions under which the expression may or may not be an integer.
  • One participant presents a logarithmic expression and questions whether it can yield an integer, suggesting that counter-examples would be appreciated.
  • Another participant suggests decomposing the logarithm to analyze when it results in a non-integer expression, assuming the initial expression is correct.
  • There is a discussion about the implications of terms like log_x(2) contributing to a decimal part, which may prevent the overall expression from being an integer.
  • Participants explore the idea of simplifying the expression and the conditions under which certain terms can be canceled or simplified.
  • Concerns are raised about the possibility of terms yielding decimals that could still result in an integer under specific circumstances.
  • One participant emphasizes that proving the non-integer condition may only require finding one example where the expression does not yield an integer.
  • A later reply questions whether the discussion is a repost of a previous thread, indicating potential overlap in topics.
Participants express differing views on the conditions under which the logarithmic expression may or may not yield an integer. There is no consensus on a definitive approach or conclusion regarding the integer status of the expression.
Participants acknowledge the complexity of the logarithmic expression and the need for careful consideration of terms and conditions that affect its integer status. The discussion includes various assumptions and potential simplifications that have not been fully resolved.
S.Iyengar
Prove that for any non-zero positive integers [itex]b,s[/itex]
[itex]a = \large \log_x \bigg(\dfrac{ ( -3 + x^{2b} ) \pm \sqrt{(3-x^{2b})^2-4x^{2b}(1-s^2)}}{2x^{2b}}\bigg)\notin \mathbb{Z}.[/itex]​
The above expression comes from the result
[itex]x^a = \dfrac{ ( -3 + x^{2b} ) \pm \sqrt{(3-x^{2b})^2-4x^{2b}(1-s^2)}}{2x^{2b}}.[/itex]​
Edit : The [itex]x^a[/itex] present there comes from the root of quadratic equation in terms of [itex]x^a[/itex] which is
[itex]x^{2b}.x^{2a} +(3-x^{2b}) x^{a} + (1-s^2)=0 .[/itex]​
There [itex]a \ge 1, b \ge 1, s \equiv 0 \mod 2, x[/itex] is a prime [itex]\gt3[/itex].
P.S. : I don't know whether [itex]a[/itex] turns to integer or not . Any counter-examples that make [itex]a \in \mathbb{Z}[/itex] are highly appreciated. I have substituted some random values and got the numerator always less than denominator, and there by creating an obstruction for [itex]a[/itex] to be an integer. So can we have some comparisons on the numerator and denominator ? .
Thank you.
Mathematics news on Phys.org
Hey S.Iyengar.
The first thing I think you should do is to decompose the logarithm with respect with the x terms (since log_x(x^(2b)) = 2b and similar for other terms) and then figure out when you get a non-integer expression from there.
I'm going to assume that your expression is correct for getting a, and if it is then proving it will involve showing that your final log expressions give a non-integer number and this only happens when you get log_x(f(x)) is an integer.
Maybe you could do this first and then offer any insight you have had from this.
chiro said:
Hey S.Iyengar.
Yes, but given a surd, we can't bring that expression into that form. I hope if you see my latest edit you will understand what I mean
But you can at least pull some terms out and then see what the minimal condition is for the expression to be an integer. I didn't mean to imply that you can just get a clean answer, but instead an implicit constraint that needs to hold for the integer condition to hold.
Also I'm wondering, are there any simplifications you can do for the +- part as opposed to just having it in that form (i.e. expanding explicitly the + and the - to get simplifications)?
Yes may be you are right .
I did something else to make it appear as follows . Log (a/b) = log a - log b. It makes a term [itex]Log_x(2)[/itex] in the expression ( that arises when we expand [itex]\log_x(2x^{2b})[/itex]. So that [itex]Log_x(2)[/itex] may contribute to some decimal part . How about this ?.
Yes that is the kind of thing I am getting at, but you will have to consider all parts of the relationship.
In the case of an integer, you should always be able to cancel these kinds of terms and be left with a variable that you know has an integer expression. If you end up in a situation where you can not simplify or cancel things like log_x(2) or log_x(s) or something like that, then you have proven the non-integer condition.
Of course the modulus conditions will give you more ways to simplify the problem, but the idea still stands.
Dear sir,
But that may not seem to work perfectly. If the term also gives some decimals and make it cancel both the sides then it would become an integer.
S.Iyengar said:
Dear sir,
If you want to use this kind of case, you will need to specify exactly when this happens and this will tell you when you get this case, and if this case is not for all values of a,b,s,etc then you still have proven that at least some cases exists where you get a non-integer value and you're done (remember you only have to show one example of it not being true).
So for example if you end up with log_x(2) + log_x(4s) = a (just an example, not the real answer) then it means that log_x(8s) = a which means that 8s = x^a. If we let say s > 0 then there are many ways of getting this, but again we can have lots of values that contradict a being an integer.
Did you try anything better ?
No I haven't since this is not my problem. I'm merely trying to throw any ideas at you that may or may not help you solve your problem. I don't want to solve it for you, but certainly if I can think of a way that aids you in doing so, I will definitely mention that idea.
