Applying Reynold's Theorem to Infinitesimal Element: Fluid Dynamics
The discussion focuses on the application of Reynold's transport theorem to an infinitesimal element in fluid dynamics. Participants explore the implications of applying the theorem to both point and infinitesimal volumes, examining the resulting equations and the differences between Lagrangian and Eulerian formulations.
  • One participant presents the application of Reynold's transport theorem and derives an unexpected term when applying it to an infinitesimal element.
  • Another participant suggests that the initial equation presented may be incorrect, referencing external material for comparison.
  • A later reply acknowledges the correction but notes that the original problem persists, indicating a potential misunderstanding of the behavior of infinitesimal volumes.
  • Further discussion introduces the idea that the extra term may reflect the volume change of the infinitesimal element, which is significant and not negligible.
  • One participant clarifies that the transport equation applies to finite volumes that move with the fluid, emphasizing the fundamental differences between Lagrangian and Eulerian perspectives.
  • Another participant reflects on the implications of not considering the size change of infinitesimal volumes, leading to a revised understanding of the transport theorem.
  • A suggestion is made to consider analogous 1-D problems to better visualize the differences in behavior between fixed and moving volumes.
Participants express differing views on the application of Reynold's transport theorem to infinitesimal volumes, with some suggesting that both results may be valid under different conditions. The discussion remains unresolved regarding the implications of these findings.
Participants note the limitations of applying concepts from finite volumes to infinitesimal elements, highlighting the need for careful consideration of volume changes and the assumptions involved in the derivations.
nonequilibrium
So Reynold's transport theorem states that [itex]\frac{\mathrm d}{\mathrm d t} \int_{V(t)} f \; \mathrm d V = \int_{V(t)} \partial_t f \; \mathrm d V + \int_{V(t)} \nabla \cdot \left( f \mathbf v \right) \; \mathrm d V[/itex].
Now I would expect (on basis of conceptual reasoning) that if I were to apply this to an infinitesimal element around [itex]\mathbf r(t)[/itex], I should get the well-known (the so-called convective derivative) result [itex]\frac{\mathrm d}{\mathrm d t} f(\mathbf r(t)) = \partial_t f + \left( \mathbf v \cdot \nabla \right) f[/itex]
However, it's straight-forward to see that one gets [itex]\frac{\mathrm d}{\mathrm d t} f(\mathbf r(t)) = \partial_t f + \nabla \cdot \left( f \mathbf v \right)[/itex]
I get a term [itex]f \; \nabla \cdot \mathbf v[/itex] too much. What gives?
You're correct, thank you. To keep it clean I fixed my mistake in the OP. However, it seems the problem remains...
On further thought, both results might be correct and they might indicate a fundamental difference between a "point" and an "infinitesimal volume": the extra term indicates the volume change of the infinitesimal volume, which apparently is not negligible.
The transport equation you wrote applies to any finite volume which moves with the fluid (and changes size and shape as it moves, in general).
If you want to work with a fixed volume in space, you get a different form of the transport equation. The difference between the two (i.e. the Lagrangian and Euleran formulations) is fundamental. Of course you can transform one equation into the other. In one form you the boundary moves. In the other, there is fluid flow through the fixed boundary.
But you can't chop a finite sized moving volume into a sum of "infinitesimal" parts that are fixed in space, and just hope things will work out OK!
Oh but I wasn't keeping it fixed in space, I had simply not entertained the thought that an infinitesimal volume would also change in size, which it does, by a factor of [itex]\nabla \cdot \mathbf v[/itex]. Keeping this in mind, for the infinitesimal volume we get [itex]\frac{\mathrm d}{\mathrm d t}\left( f \mathrm d V \right) = \left( \frac{\mathrm d}{\mathrm d t}f \right) \mathrm d V + f \; \nabla \cdot \mathbf v \; \mathrm d V[/itex] where the second derivative w.r.t. to time is the convective derivative.
Alternatively, this leads to a different way to prove Reynold's transport theorem, i.e. one can show on grounds of physical reasoning that an infinitesimal volume changes in size with factor [itex]\nabla \cdot \mathbf v[/itex]. Reynold's transport theorem follows from this.
That's one reason why I try to stick with finite volumes, whenever possible :smile:
One way to dig yourself out of this sort of hole is to back off and think about an analogous 1-D problem. You can convince yourself of the difference between say $$\frac{d}{dt}\int_a^b f(x,t)\,dx\quad\mathrm{and}\quad\frac{d}{dt}\int_{a(t)}^{b(t)} f(x,t)\,dx$$ by drawing pictures of the area under the curve at times ##t## and ##t + \delta t##. But drawing pictures of 3-D vector fields in arbrtrary regions is hard!
  • · Replies 24 ·
  • · Replies 29 ·
