| New Reply |
How to calculate quadrotor propeller torque due to aerodynamic drag |
Share Thread |
| Jul12-12, 05:45 AM | #1 |
I'd like to know the right formula to calculate torque of a quadrotor propeller (propeller pitch is constant) due to aerodynamic drag in terms of angular velocity ω. For the sake of my simulation I'm assuming `APC 10x4,7` propellers. I'd like to refer to UIUC Propeller Data Site, so please assume only the set of data given there is available while answering. I know really little of aerodynamics, I'm planning to design a control system in Simulink later on, but would like to derive a non-linear mathematical model first.
Please note I need to use data from UIUC Propeller Data Site for APC 10x4,7, which means the propeller below. I'm guessing all is there to derive a formula τ(ω), I just don't understand how to do it. ![]() ![]() ![]() Static data from UIUC: RPM CT CP 2377 0.1039 0.0431 2676 0.1058 0.0437 2947 0.1059 0.0437 3234 0.1083 0.0444 3494 0.1096 0.0450 3762 0.1121 0.0460 4029 0.1136 0.0466 4319 0.1155 0.0474 4590 0.1177 0.0484 4880 0.1199 0.0494 5147 0.1213 0.0500 5417 0.1228 0.0508 5715 0.1239 0.0513 5960 0.1253 0.0520 6226 0.1261 0.0524 6528 0.1274 0.0531 |
| Jul14-12, 12:12 AM | #2 |
If you want to take a stab at this model you find a motor that will operate at some range of RPMs given on the table and use the formula [itex]C_T = \frac{T}{\rho n^2 D^4}[/itex] Where T is thrust, D is the blade diameter, n is RPS (convert to RPM) Then you can multiply by some efficiency factor [itex]\eta[/itex] ~0.95 or so to account for heat losses etc... You will probably end up with a lookup table and not a formula |
| Jul15-12, 03:11 AM | #3 |
| Oct8-12, 04:52 PM | #4 |
Quad rotors are usually designed so that the props are counter-rotating and thus, the reaction torques are self compensated (for most maneuvers). For maneuvers that they are not self-compensated, they are negligible. I just completed my thesis and worked with the APC 12x9 prop. Trust me, it would not be worth adding to the simulation. Although, the model would look more complete if you do add them.
| New Reply |
| Tags |
| drag, propeller, torque |
Similar discussions for: How to calculate quadrotor propeller torque due to aerodynamic drag
| Aerodynamic Drag | Classical Physics | 5 | ||
| How calculate propeller efficiency if I know propeller trust? | General Engineering | 47 | ||
| Aerodynamic Drag Stabilization (Ballistic Application) | Mechanical Engineering | 9 | ||
| Aerodynamic Drag Problem | Calculus | 7 | ||
| projectile motion with aerodynamic drag | Introductory Physics Homework | 3 | ||
