Determining the deflection of a support rod during acceleration
The discussion centers around determining the deflection of a support rod connected to a robot during acceleration, specifically when the robot accelerates or decelerates at a maximum rate of 1 m/s². Participants explore both analytical and simulation approaches to understand the deflection caused by the inertia of the housing and camera attached to the rod.
  • One participant suggests modeling the rod as a cantilever beam with a force at the end, calculating maximum deflection based on the acceleration force on the camera.
  • Another participant questions the simplification, noting that the robot's base is accelerating, not the camera, and raises concerns about treating the dynamic system as static.
  • Concerns are expressed regarding the axial load of the housing and components, which could become significant once the rod starts to deflect.
  • Some participants agree that starting with a static analysis is reasonable, with the possibility of increasing complexity later if necessary.
  • One participant argues that the mass at the end of the rod will accelerate with the robot, and unless the rod is undersized, the axial loading may not be a major concern compared to bending loads.
  • Discussion includes the suggestion to calculate the first mode of vibration for the beam/mass system to assess stiffness under acceleration.
  • Participants clarify that the bending caused by axial forces is minor compared to that caused by acceleration, and the moment arm for axial forces is smaller.
  • There is a discussion about the implications of deflection on the bending moment at the base of the beam and how to account for it in calculations.
Participants express differing views on the significance of axial loading versus bending due to acceleration. While some suggest that axial forces can be disregarded, others argue that they should be considered, especially if deflections are not negligible. The discussion remains unresolved regarding the best approach to model the system accurately.
Participants acknowledge that simplifying assumptions are necessary for analysis, but the extent of those assumptions and their implications on the design problem are debated. The discussion highlights the complexity of modeling real-world mechanical systems accurately.
rafehi
Hi all,
I'm currently designing a housing for a camera and omnidirectional mirror for a robot. The housing is connected to the robot through a rod of about 25mm diameter.
...{...}... (housing)
...|... (rod)
...(___)... (robot base)
I'm trying to compute the deflection in the rod when the robot accelerates (or deccelerates) at its max of 1m/s^2 but not sure how I'd go about it.
Conceptually, when the robot is at rest the rod would act as a column with a concentric load. Once the robot accelerates, the inertia of the rod and housing would cause it to want to stay, hence causing the deflection. Once it begins to deflect, the housing becomes an eccentric load and causes the rod to deflect more. The dimension of the rod is fixed so I have to ensure the housing is light enough to minimise deflection and vibration.
At this stage I'm looking at doing a rough FEA simulation and seeing what numbers it spits out but how would you go about solving such a problem analytically?
Is it really that simple? The base of the robot is what's accelerating, not the camera (housing). I guess we can use the robot as the reference frame and take the base of the rod to be fixed, with the housing accelerating, however will modelling the dynamic system as static be a reasonable approximation?
Also, given the housing + components is relatively heavy (1-2kg), surely the axial load cannot be ignored? Once the rod starts to deflect, it'll become a pretty significant eccentric load.
Looking at it in the static case is a good start in my opinion, and you can increase complexity with a dynamic analysis if your findings make it seem necessary.
Making assumptions to simplify your analysis is engineering 101, but only you can decide "what's necessary." Step 1 is to put bounds on how much your beam will deflect so you can decide what else might contribute to the design problem.
You are way overthinking this. You've got a mass (1-2 kg) at the end of a rod. They are connected, so if the robot accelerates, so does the mass (they are connected after all).
You are correct in that the inertia of the mass will mean it wants to resist that acceleration. That's why F=m*a. Hence the deflection. Unless your rod is so undersized that the thing actually bends, I don't think you'll have to care as much about the axial loading. The bending (and the uplift at the connecting rod mounting point) will be your most significant loads.
You also might calculate the first mode of virbration for the beam/mass, because that number will give you some insight into how stiff it is and how it will hold up to acceleration applied over a certain time constant.
Have always struggled reducing a real world mechanical problem down to a simple model. Working on it...
Just to clarify with a FBD of the external forces:
http://img259.imageshack.us/img259/1201/84664287.jpg
However, assuming that the column isn't going to buckle under the load (not going to happen), the bending caused by the axial force is relatively minor compared to that caused by the acceleration, due to the much smaller moment arm, therefore Fy can be disregarded.
That's an easy calculation to do too.
What "bending caused by the axial force" are you referring to exactly? A purely axial force does not cause a moment, is the load not centered on the beam? The acceleration will impart a small moment at the end of the beam (unless you assume the C.G. of the mass is attached to the beam), but you can take that into account if you like with a moment and force applied at the end of the beam... but as you said it will probably be much smaller than the bending moment at the base of the beam.
He's talking about additional bending load on the rod when the mass is deflected. The mass no longer acts axially, and as a result the mass alone will create additional moment on the rod. As we've said, though, unless we are talking about large deflections here (in which case your rod is too flexible), this should be treated as minimal (unless you want a fully detailed, dynamic result)
Gotcha, yes I would assume that the deflection on the rod is small. Remember that the force would be subject to sin(theta), so if the beam deflects 1 degree only about 2% of the weight is contributing to a bending moment. If your beam deflection is significant enough to contribute to additional bending moment at its base from a vertical force, I would recommend stiffening the member.
Take a look at the first vibrational mode of the beam/mass system and get back to us.
  • · Replies 55 ·
11K
  • · Replies 30 ·
10K
