Calculate Dead Load of Beam w/ Solid Square Cross Section
The discussion centers on calculating the dead load of a beam with a solid square cross section of 100mm, supported by two points 3m apart. The participant initially calculated the dead load as 720N using the volume of the beam and the unit weight of reinforced concrete (24KN/m³). However, the correct interpretation of dead load involves considering additional loads applied to the beam, rather than the weight of the beam itself. Clarification was sought regarding the properties of the beam material that affect the maximum supported load.
  • Understanding of solid square cross section calculations
  • Knowledge of reinforced concrete properties
  • Familiarity with load calculations in structural engineering
  • Basic principles of beam support and loading conditions
  • Research "Reinforced Concrete Load-Bearing Capacity" to understand material limits
  • Study "Beam Deflection Calculations" for additional load considerations
  • Learn about "Static Equilibrium in Structural Engineering" for support analysis
  • Explore "Dead Load vs Live Load in Structural Design" for load classification
Structural engineers, civil engineering students, and professionals involved in beam design and load calculations will benefit from this discussion.
sperrya
A beam has a solid square cross section of 100mm and is simply supported by two supports 3m apart. Calculate the dead load that can be safely supported when applied to the middle of the beam.
Solid square cross section of beam: 100mm
Material: unknown
Distance between two beams: 3m
Assumption: material is reinforced concrete
weight of material: 24KN/m3
Area of square = height x width
volume = area of solid x length
dead load = volume x unit weight of material
area of square = 100mm x 100mm = 10,000mm2 (0.0100m2)
volume = 0.0100m2 x 3m = 0.0300m3
dead load = 0.0300m3 x 24KN/m3 = 0.72KNVm3
∴ dead load = 0.72KNVm3 / m3 = 720N
Can someone please tell me where I am going wrong with this as I have been advised this is wrong but I don't know where.
Thanks in advance for your help.
hi sperrya! :smile:
no, that's not a dead load, that's the weight of the beam
a "dead" load is an extra load on top of the beam (in this case, at its middle) …
what are the properties of the material of the beam that determine how much extra load can be supported? :wink:
15K
