Maximum Height for Hanging Mass on a Stretched Wire
  • Thread starter Thread starter Catchfire
    Wires
The discussion revolves around two problems related to the behavior of a wire under tension and the effects of a hanging mass. The first problem involves determining the depression of a midpoint of a wire when a mass is hung from it, while the second problem focuses on calculating the maximum height from which a mass can be dropped without breaking a steel wire.
  • Mixed
  • Participants explore the relationship between tension and the stretching of the wire, questioning assumptions about the wire's behavior in different configurations (vertical vs. horizontal).
  • Some participants attempt to derive expressions for tension and stretch using trigonometric relationships and Hooke's law.
  • There is a discussion about the application of energy concepts in the second problem, with participants questioning the validity of constant acceleration assumptions.
Participants have made progress in understanding the first problem, with one arriving at a potential solution for the depression of the midpoint. The second problem is still under exploration, with guidance provided on using energy principles to approach the solution. There is an acknowledgment of the complexities involved in both problems, particularly regarding the varying tension in the wire.
Participants note that the wire's tension differs significantly between vertical and horizontal configurations, affecting the amount of stretch. Additionally, there are constraints related to the assumptions made about the mass's acceleration and the wire's properties, which are under discussion.
Catchfire
Hello first post here. These problems aren't for a specific course just working through an old textbook specifically Vibrations and Waves by A.P. French. I hope it's alright that I include two problems in one thread.
Q 3-7) A wire of unstretched length L0 is extended by 10^-3L0 when a mass m is hung from it's end. If this same wire is connected between two points A,B horizontally and then the same mass is hung from the middle of the wire, how large is the depression y of the midpoint?
The answer given is L0/20.
x^2 + y^2 = h^2
I assume the total length of the wire will still be (1 + 0.001)L0. So dividing the length in two and the unstretched length in two you get a right angle triangle.
(L0/2)^2 + y^2 = (L0(1+0.001)/2)^2
y = (L0(1+0.001)/2)^2 - (L0/2)^2))^0.5
= ((0.5005^2 - 0.25)L0^2)^0.5
= 0.022 L0
Q 3-8b) A 0.5kg mass is hung from a 2m long steel wire with diameter 0.5mm. What is the maximum height h the mass can be dropped from if the wire is not to break?
Young's modulus of steel: 2x10^11 N/m^2
Ultimate strength of steel: 1.1x10^9 N/m^2
The given answer is 0.23m
Y = (F/A) / (ΔL/L)
US = F/A
F = ma
v0^2 = v - 2aΔx
KE = 0.5mv^2
GPE = mgh
F = US x A = 1.1x10^9 x ∏(0.0005/2)^2 = 216 N
The thing that's throwing me off is that if I have a falling mass I have a energy and not a force. So I'm thinking maybe look at the acceleration over the distance the wire stretches.
a = 216/0.5 = 432 m/s^2
ΔL = FL/YA = (216 x 2) / ((∏(0.0005/2)^2)(2x10^11)) = 0.011m
v0^2 = 0 - 2(9.8)(0.011) = 9.5 m/s
0.5mv^2 = mgh
0.5(9.5) = 9.8h
h = 0.48mAny help with this problems is much appreciated, thanks.
Catchfire, this is not a correct assumption. The wire stretches by .001Lo if the wire is suspended vertically and then mg is hung on the end. In this case the tension in the wire is mg. However, when the wire is suspended horizontally and mg is hung in the middle, the tension in the wire will be much greater than mg. So, the wire will stretch much more than .001Lo.
So, you might start by trying to find an expression for the tension in the wire in terms of mg and the angle θ, where θ is the angle the wire makes to the horizontal when the mass is hung in the middle. Hint: Draw a free body diagram for the hanging mass.
Thanks for the reply.
Ok so I got this far:
2Tsinθ = mg
T = mg/2sinθ
I know T is supposed to be 5mg so sinθ = 0.1 but I'm lost as to how that works out.
Very good. Note that you have shown that the tension has increased by a factor of 1/(2sinθ) compared to just hanging the mass on the vertical suspended wire. So, if the wire stretched by .001Lo when it was vertical, how much will it stretch when horizontal? Express this in terms of Lo and sinθ.
Try to construct a right triangle with the angle θ and with the sides related to the unstretched and stretched lengths. You can use trig on this triangle to get a relation between θ, Lo, and L (where L is the stretched length).
Then try to put it all together so that you can solve for θ.
For the horizontal it should be:
Tcosθ = mg cotθ/2
L_x = cotθ/2 L0
for the triangle:
(1/2)^2 + (x)^2 = (1/2sinθ)^2
1 + x^2 = 1/sin^2θ
x = (1/sin^2θ -1)^0.5
so
L_x = (1/sin^2θ -1)^0.5 L0
and
cotθ/2 = (1/sin^2θ -1)^0.5
cot^2θ/4 = 1/sin^2θ -1
cos^2θ/4 + sin^2θ = 1
cosθ = 0
so θ = π/2
...was it my trig?
Sorry, I didn't understand much of your last post. This is a tricky problem.
You know from your triangle: (Lo/2)2 + y2 = (L/2)2
Try substituting L = Lo+ΔL in the right hand side of the above equation. Square out the right hand side and see if you can simplify to
y2 = (LoΔL)/2 + (ΔL)2/4
Now we know that ΔL will be small compared to the overall length Lo. So, the last term may be neglected:
y2 ≈ (LoΔL)/2
We need to find an expression for ΔL. From the statement of the problem, we know that ΔL = .001Lo when the tension in the wire is mg. But when the the mass is hung on the horizontal wire, you found earlier that the tension is mg/(2sinθ). In other words the tension has increased by a factor of 1/(2sinθ).
Hooke's law tells you that the amount of stretch ΔL is proportional to the tension. So, see if you can write down an expression for ΔL when the mass is hung on the horizontal wire. [You should get that ΔL is a numerical factor times Lo/sinθ]
We can write this expression for ΔL in terms of our unknown y by writing sinθ in terms of y. Another approximation you can use is that sinθ≈tanθ (since θ should be a small angle). Use your right triangle to express tanθ in terms of y and Lo. So, you will be able to express ΔL in terms of Lo and y. If you substitute this expression for ΔL into the right hand side of the above equation for y2 you can solve for y.
Ok hopefully this is a bit clearer. :)
ΔL = 0.001 L0/2sinθ
= 0.001 L0/2tanθ
= 0.001 L0/2(y/(L0/2))
= 0.001 L0[itex]^{2}[/itex]/4y
y[itex]^{2}[/itex] = L0ΔL/2
= L0/2 0.001 L0[itex]^{2}[/itex]/4y
y[itex]^{3}[/itex] = 0.001/8 L0[itex]^{3}[/itex]
y = 0.05 L0
Which is the answer. *sigh of relief*
Thanks for your assistance and patience, mind lending a hand on my other question?
Nice work on the first problem!
For the second problem, your calculation of the tension in the wire at the breaking point (216 N) looks good to me. Also the maximum stretch of the wire before breaking (0.011 m) looks good.
However, note that the acceleration of the mass is not constant during the stretching of the wire because the tension force of the wire varies as the amount of stretch varies. So, constant-acceleration kinematic formulas are not applicable.
To use energy concepts, try ΔKE + ΔPEgrav + ΔPEwire = 0. You will need to choose appropriate initial and final points and you will need to construct a potential energy function for the stretching wire. But this will just be the usual type of potential energy function for Hooke's law (like a spring).
Ok here it goes:
ΔKE should = 0 if we're looking at the limit
so we have
mgh - 0.5kΔx2 = 0
h = 0.5kΔx2/mg
Δx = 0.011m
mg = 4.9 N
k = AY/L0
L0 = 2m
Y = 2x1011 N/m2 N/m2
A = 0.000252π m2
k = 1960 N/m
so h = 0.5(1960)(0.011)2/4.9 = 0.242m
but that h is really 0.011m below x0
so the answer is h = 0.242 - 0.011 ≈ 0.23m.
Thanks, I'm glad that one was a bit more painless.
I really appreciate your time and effort.
Great! You even saw that you needed to subtract .011 m off your initial result for h. :approve:
  • · Replies 19 ·
  • · Replies 21 ·
