Electric vs gravitational force
The discussion revolves around the comparison between electric and gravitational forces, particularly in the context of how an imbalance of charges could affect the Earth and Sun's interaction. Participants explore theoretical implications of charge imbalances, calculations of forces, and the nature of gravitational stability in stars.
  • One participant questions how an imbalance of charges, as suggested by Weinberg, would manifest in reality, particularly regarding the potential impact on Earth's orbit.
  • Another participant proposes that Weinberg may have omitted a square root in his calculations, leading to a different ratio of electric to gravitational force.
  • Some participants note discrepancies in the quoted strength ratios of electric versus gravitational forces, with figures ranging from 10^36 to 10^40.
  • There is a suggestion to calculate the gravitational and electric forces between the Earth and Sun under different surplus proton scenarios to compare their magnitudes.
  • One participant emphasizes the nature of forces between protons, questioning which force—gravitational or electrostatic—is stronger and by what margin.
  • Another participant expresses concern about the necessary imbalance of electrons over protons required to displace the Earth from its orbit, given the vast number of protons involved.
  • A later reply corrects a previous claim about the number of protons and electrons in the Earth, suggesting a much smaller imbalance than initially thought.
  • Participants also discuss the balance of forces in the Sun, questioning how gravitational forces counteract the outward pressure from nuclear fusion, with one participant asserting that these forces are in perfect equilibrium.
Participants express various viewpoints on the calculations and implications of electric versus gravitational forces, with no consensus reached on the correct ratios or the impact of charge imbalances. The discussion remains unresolved regarding the specifics of these forces and their effects.
Participants reference specific calculations and theoretical scenarios, but there are unresolved mathematical steps and assumptions regarding the nature of forces and charge distributions.
g.lemaitre
In the First Three Minutes Weinberg wrote:
If the Earth and the sun had an excess of positive over negative charges (or vice versa) of only one part in (10^36), the electrical repulsion between them would be greater than their gravitational attraction.
How would that imbalance actually manifest itself in the real world? Does that mean that if for every 10^36 protons the sun had 10^36 + 1 electrons and if the Earth for every 10^36 electrons had 10^36 + 1 protons, then that would knock the Earth out of orbit? At first glance it seems ridiculous but considering the fact that the Earth has 10^50 protons that means that the Earth would have, I think, 10^14 extra protons than electrons, but even 10^14 electrons is hardly a lot considering that a mole is 10^23. My math must be off somehow.
I think Weinberg must have omitted a square root in his calculation. I get a ratio of about 10^18, not 10^36.
No, I've seen that figure quotes about 20 times, sometimes I see it quoted as 10^36 times stronger, other times 10^40 times stronger. Here's one link
electricuniversetheory.com
Try it yourself. Calculate the gravitational force between the sun and earth. Then calculate the electric force assuming a surplus of protons of 10-36 times the actual number on the sun and earth, and the electric force assuming a proton surplus of 10-18. Which one is closer?
For a more precise value, use 8.998 x 10-19 for the "surplus proton" ratio.
the issue is, that two protons alone in free space will have a [itex]1/r^2[/itex] gravitational force that is attractive and another [itex]1/r^2[/itex] electrostatic force that is repulsive. since they are both [itex]1/r^2[/itex], it doesn't matter what distance the protons are from each other (at least in this classical setting). so which force is stronger? the attractive gravitational force (that depends on the masses of the two protons) or the repulsive electrostatic force (that depends on the charges of the two protons)? and by how much?
I'm pretty sure the EM force would matter in your above example. What I'm worried about though is how much of an imbalance of electrons over protons you need on the Earth and Sun before the Earth gets forced out of orbit, provided the Earth has 10^50 protons and the Sun 10^57 protons.
g.lemaitre said:
... At first glance it seems ridiculous but considering the fact that the Earth has 10^50 protons that means that the Earth would have, I think, 10^14 extra protons than electrons,... My math must be off somehow.
Actually the Earth would have only one more proton
Since were on the topic of gravity how does the sun's gravity prevent it from blowing up into space? Because if its energy comes from nuclear fusion wouldn't the pressure from this reaction push the particles away?
The sun is held in perfect equilibrium. Gravity wants to crush it to a point and the pressure from the fusion wants to push it outward. The outward force of fusion and the inward force of gravity are perfectly balanced and all of this is done without teleology.
  • · Replies 20 ·
  • · Replies 18 ·
  • · Replies 19 ·
