How do you calculate the integral dz/(z^2+h^2)^(2/3)?
  • Context: Undergrad
  • Thread starter Thread starter NadAngel
    Integral
The discussion revolves around the calculation of the integral ∫dz/(z^2+h^2)^(3/2), which is related to problems in electrostatics. Participants explore various methods of integration, including substitution techniques and the possibility of expressing the integral in terms of special functions.
  • One participant expresses difficulty in solving the integral using integration by substitution and suggests that h is a constant.
  • Another participant challenges the correctness of the provided solution and suggests verifying it through differentiation.
  • A different participant proposes that the integral may not have a solution expressible in terms of standard functions, suggesting it might involve a Hypergeometric function or an Incomplete Beta function.
  • After a clarification regarding a typo, the same integral is confirmed, and one participant claims it can be solved simply by rearranging and making a trigonometric substitution.
Participants do not reach a consensus on the method of solving the integral. Some suggest it may require special functions, while others propose simpler methods involving trigonometric substitutions.
There are unresolved assumptions regarding the methods of integration and the applicability of certain functions. The discussion includes a mix of proposed techniques without a definitive resolution on the integral's solvability.
Readers interested in advanced calculus, integral calculus, and applications in physics, particularly in electrostatics, may find this discussion relevant.
NadAngel
I am trying to solve a problem I saw in a book about electrostatics. In the book the solution to the integral ∫dz/(z^2+h^2)^(3/2) is z/(h^2*(z^2+h^2)^(1/2) but I can't solve the integral by myself. I have tried integration by substitution but I can't seem to solve it.
u=z^2+h^2
du=2zdz
dz=du/2z
This does not yield a correct result.
PS: h is a constant, so you only need to integrate it by dz.
Hey NadAngel and welcome to the forums.
That answer is not correct and you can differentiate the answer to see if it equals the expression inside the integral from the fundamental theorem of calculus. I would try this and do this first.
For the substitution though wikipedia has a good list of integral tables:
http://en.wikipedia.org/wiki/List_of_integrals_of_rational_functions
Hi !
I doubt that you could integrate it with this method.
I think that this integral cannot be expressed as a combination of a finite number of usual fuctions. The closed form will probably requires an Hypergeometric function, or more simply, an Incomplete Beta function.
Thank you for the replies. It seems I have made a typo in the post and the correct integral of interest is:
∫dz/(z^2+h^2)^(3/2)
The solution in the book is the same: z/(h^2*(z^2+h^2)^(1/2)
Can this be soved?
∫dz/(z^2+h^2)^(3/2)
Can this be soved?
Yes, quite simply too.
First rearrange algebraically to get:
[tex]\frac{1}{h^3}\int {[1 + {(\frac{z}{h})}^2]}^{-\frac{3}{2}} dz[/tex]
Then make the substitution [tex]\frac{z}{h} = \tan \theta[/tex].
Can you take it from there? Remember your trig identities.
  • · Replies 21 ·
