Work Energy Method for Rotational Motion
The discussion revolves around the work-energy method in the context of rotational motion, specifically addressing the work done by frictional forces and the relationship between linear and rotational motion in a system involving a falling mass and a rotating drum.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the relationship between linear and rotational motion, questioning how both types of motion contribute to the work done in the system. They discuss the use of tension and frictional force in calculating torque and work, raising questions about the definitions and applications of these concepts in different contexts.
Participants are actively engaging with the problem, seeking clarification on the roles of different forces and how they relate to the work-energy method. Some have provided insights into the distinctions between torque due to tension and friction, while others are confirming their understanding of the concepts involved.
There are references to specific diagrams and parts of the problem that may not be fully detailed in the discussion, leading to some confusion about the application of concepts across different contexts. Participants are navigating these complexities without a clear consensus on all points raised.
freshbox
Reference to part C of the question, I would like to ask for work done U1to2, how come linear motion is not included? I thought both linear and rotational exist since the parcel "move downwards" (linear) and the wheel is rotating (rotational)
Thanks...
Part C asks for the work on the drum. Why worry about the falling mass? They want you to calculate the work directly.
Oh you you are right, sorry didn't read the question clearly :redface:
Just to confirm if they ask me to find the work of frictional force, Fr on the drum and falling mass between position 1 and 2 both linear and rotational will exist correct?
With regards to part c again, To find Torque τ, I know that τ=Tension X Radius so comparing diagram 1 (left) against diagram 2 (right) which i drew a red line to indicate Tension.
How come in the Work Done equation it uses the Frictional Force X Radius and not Tension X radius?Thanks...
If the mass falls and the drum rotates, sure there will be both linear and rotational motion and kinetic energy.
Realize that those diagrams refer to different problems.
Part c asks you for the work done by the frictional force, not the tension.
My lecturer told me that τ = tension X radius this concept on the chapter of Kinetics of rotational motion diagram 1 (left)
But he never mention this on the chapter of Work Energy method for rotational motion diagram 2 (right). However, I thought they have the same meaning since both are τ in both formula.
So are you trying to say U1-2=τ X δ
The τ in the equation is actually the frictional force?
And can I say that Torque in τ=Iα and U1-2=τ X δ are actually both different thing?
You can calculate the torque due to any force. If the force is tangential to the wheel, then τ = Force X radius. Depending upon the particular problem, that force can be a tension force or a friction force.
Right. The torque in that equation is due to the friction force. You are asked to find the work done by the friction force, so you'd use the torque created by that force to calculate the work.
Yes, those are different things. The first equation is just Newton's 2nd law as applied to rotation; the torque in that formula should really be the net torque: Ʃτ=Iα.
The second equation is an expression for the work done by some torque. In your problem, it's the work done by the frictional force, which is non-conservative work that will decrease the total mechanical energy of the system.
Thank you sir for the clarification.
