New Reply
Automatic Gate
Share Thread Thread Tools
Jul16-12, 01:44 PM   #1
Automatic Gate
I need to automate a gate that is 4.91mtr in length, the motion should be swing type and the angle of rotation to be about less than 180 degree. and the mass of the gate is about 300kg, now should I use a dc motor and if so what should be rating of the same, the rpm required about 5-8...
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Sensitive bomb detector to rove in search of danger
>> PNNL-developed injection molding process recognized with emerging technologies award
>> How soon could car seats enter the 3-D comfort zone?
Jul17-12, 02:46 AM   #2
Recognitions:
Gold Membership Gold Member
Welcome to PF, Arvin.
In this instance, I'd be very much inclined to use a boat-house type of winch with a cable to operate the gate. To simplify things, a heavy spring system could be used for the opposite travel (which way to be determined by whether you want it to be fail-safe or fail-secure).
Jul17-12, 08:43 AM   #3
Recognitions:
Most large gates like this utilize a 4-bar mechanism and gearmotor to operate them. Are you familiar with either of these?
Jul30-12, 12:34 AM   #4
Automatic Gate
Quote by Mech_Engineer View Post
but in four bar mechanism the rod that will be supplying power from the motor has to be of a large length as the length of gate is about 4.9mtr. so it will definetly create a bending in it.....
what will be the hp required if a dc motor with worm gear arrangement is placed on the supporting or on the axis of rotation of the gate
Jul30-12, 09:17 AM   #5
Recognitions:
Honestly it's just an engineering design problem, there's nothing preventing the problem from being solved other than your doubts.
Have you researched how existing designs are implemented?
Jul30-12, 11:28 PM   #6
how much hp motor is required if we use an dc motor, and how can we calculate the angular force required for the same.
Jul31-12, 09:51 AM   #7
Recognitions:
Don't worry about the power, worry about the torque. With a gate weight and some basic deisgn of the opening mechanicsm (and speed you want it to open), you can back-calculate the required motor torque and gearbox reduction ratio.
Aug4-12, 02:26 AM   #8
since i am planning to rotate the gate from its shaft .. i have calculated torue from the equation as I= (mh^2)/3 + (mw^2)/12
after that multiplied I with 3.142/2
to calculate torue
as m = 400kg in my case
h=2.5m
w=5m
and angle (alpha)= 90
so torque is 2618 NM
and the power of the motor i calculated from
power (kwh) = torque * 2* 3.142 * rpm / 60000
from which power is 3 .2 kw motor.. can u please tell if the calculations are right
New Reply
Tags
automatic, bevel gear, dc motor, gate, worm gear
Thread Tools
Similar Threads for: Automatic Gate
Thread Forum Replies
Implement ABC'D' using only one 2-input nand gate and one 3-input nor gate Engineering, Comp Sci, & Technology Homework 2
XOR gate to XNOR gate boolean algebra Engineering, Comp Sci, & Technology Homework 6
What happens when you place a NOT gate before and after a NAND gate Engineering, Comp Sci, & Technology Homework 11
need help regarding automatic transmission Mechanical Engineering 3
any gate i can substitute to xor gate? Computing & Technology 8
