Complex number exponential subtraction
The discussion revolves around the mathematical manipulation of complex numbers, specifically focusing on converting the expression Ke^{j\delta} - Ke^{j\psi} into the form re^{j\theta}. The scope includes mathematical reasoning and problem-solving related to complex exponentials.
  • Homework-related
  • One participant expresses difficulty in converting the subtraction of complex exponentials into the desired form and references a previously solved addition problem.
  • Another participant suggests using the identity e^{i(\psi + \pi)} = -e^{i\psi} to modify the expression for subtraction.
  • A third participant provides a detailed approach using the half-angle formula, demonstrating how to express the subtraction in terms of sine and exponential functions.
  • A later post raises a question about the implications of differing base factors in the subtraction and addition formulas, indicating a need for clarification on this aspect.
Participants do not appear to reach a consensus on the approach to the problem involving different base factors, as one participant seeks further clarification on this issue.
The discussion includes assumptions about the applicability of certain mathematical identities and formulas, which may depend on the context of the problem. There is also an unresolved aspect regarding the treatment of different base factors in the expressions.
Students or individuals studying complex numbers, particularly those working on problems involving complex exponentials and their manipulations.
Exulus
Hi all,
Im having a bit of trouble with a question. I have to convert:
[tex]Ke^{j\delta} - Ke^{j\psi}[/tex]
Into the form
[tex]re^{j\theta}[/tex]
This is the second part of the question, the first part was an addition instead of subtraction which i managed by using this formula:
[tex]z_1 + z_2 = K(e^{j\delta} + e^{j\psi}) = Ke^{j(\delta + \psi)/2}(e^{j(\delta - \psi)/2} + e^{-j(\delta - \psi)/2}) = 2K\cos((\delta - \psi)/2).e^{j(\delta + \psi)/2}[/tex]
I can't really see where to go with the subtraction though...is it maybe to do with a sin rule? To be honest i don't fully understand the formula above but it was given to us...Ive fiddled around with the maths for a while but its totally headbanging :( Hoping someone can help!
Since you already have a formula for sums, how about using the fact that [itex]e^{i(\psi+ \pi)}= e^{i\psi}e^{i\pi}= -e^{i\psi}[/itex]? In other words, replace [itex]\psi[/itex] with [itex]\psi+ \pi[/itex] in your formula.
Okay.It's not difficult.Jst follow the same pattern using the half angle
[tex]D=z_{1}-z_{2}=Ke^{j(\frac{\delta+\psi}{2})}[e^{j(\frac{\delta-\psi}{2})}-e^{j(\frac{\psi-\delta}{2})}]=Ke^{j(\frac{\delta+\psi}{2})}[e^{j(\frac{\delta-\psi}{2})}-e^{-j(\frac{\delta-\psi}{2})}]=[2jK\sin(\frac{\delta-\psi}{2})]e^{j(\frac{\delta+\psi}{2})}[/tex]
Okay?
Daniel.
brilliant thanks for your help! :)
URGENT: Can anyone help me with this?
Can anyone tell me what difference it makes to the subtraction/addition formulae when the base factors are not the same? i.e
[tex]D=z_{1}-z_{2}=Ke^{j(\delta)}-Le^{j(\psi)}[/tex]
I have fiddled with the above formulae, but can't seem to get anything sensible looking from it... And I need to solve this quite urgently!
Thanks in advance...
