| New Reply |
System of three equations and four variables |
Share Thread |
| Jul18-12, 10:05 AM | #1 |
How to solve this system?
\begin{align} & \sqrt{\frac{x_{1}^{2}x_{4}^{2}}{4}-{{({{x}_{1}}-{{x}_{4}})}^{2}}}-\sqrt{\frac{x_{1}^{2}x_{3}^{2}}{4}-{{({{x}_{1}}-{{x}_{3}})}^{2}}}=\sqrt{\frac{x_{3}^{2}x_{4}^{2}}{4}-{{({{x}_{3}}-{{x}_{4}})}^{2}}} \\ & \sqrt{\frac{x_{1}^{2}x_{4}^{2}}{4}-{{({{x}_{1}}-{{x}_{4}})}^{2}}}-\sqrt{\frac{x_{1}^{2}x_{2}^{2}}{4}-{{({{x}_{1}}-{{x}_{2}})}^{2}}}=\sqrt{\frac{x_{2}^{2}x_{4}^{2}}{4}-{{({{x}_{2}}-{{x}_{4}})}^{2}}} \\ & \sqrt{\frac{x_{1}^{2}x_{3}^{2}}{4}-{{({{x}_{1}}-{{x}_{3}})}^{2}}}-\sqrt{\frac{x_{1}^{2}x_{2}^{2}}{4}-{{({{x}_{1}}-{{x}_{2}})}^{2}}}=\sqrt{\frac{x_{2}^{2}x_{3}^{2}}{4}-{{({{x}_{2}}-{{x}_{3}})}^{2}}} \\ \end{align} Thanks a bunch! |
| Jul18-12, 10:40 AM | #2 |
Welcome to the physics forum!
Before we can help you, you need to show what you've tried and the steps you've taken to solve this homework problem. I did notice that you have some repeated terms in the equations that may hint at a solution like the first square-root term of the equation is repeated as the first term of the second equation. Also have you tried squaring both sides to see if there's any reductions that can be made? What course did this problem come from? |
| Jul18-12, 01:19 PM | #3 |
| Jul18-12, 02:26 PM | #4 |
okay have you tried setting the 4 values to simple numbers like zero or 1. By inspection it seems that one of those might work.
| Jul18-12, 03:52 PM | #5 |
1 gives nothing good either. |
| Jul18-12, 04:26 PM | #6 |
When I set all four values to zero I get:
sqrt(0) - sqrt(0) = sqrt(0) for all eqns. |
| Jul19-12, 12:47 AM | #7 |
| Jul19-12, 10:13 AM | #8 |
could the other roots be imaginary like try 0+i?
Beyond that I don't know how else to solve these. Perhaps your teacher or other students can give you a hint. My first attempt would be to square both sides and then see if I can use the existing eqns to sub in to eliminate any sqrt terms. Also perhaps some of the more senior contributors in this forum like Mark44 or micromass could provide some advice. |
| Jul19-12, 11:02 AM | #9 |
| Jul19-12, 02:49 PM | #10 |
Since there are 3 equations and 4 unknowns, the best you can do is to solve for the ratio of three of the parameters to the forth parameter. |
| Jul19-12, 03:52 PM | #11 |
| Jul19-12, 08:58 PM | #12 |
chet |
| Jul20-12, 03:06 AM | #13 |
Recognitions:
Use the notation
[tex] f(x,y)=\sqrt{\frac{x^{2}y^{2}}{4}-{{({{x}}-{{y}})}^{2}}}[/tex]. f(x,y) is symmetric for the interchange of the variables: f(y,x)=f(x,y) It can be derived from the equations given that f(a,b)-f(a,c)=f(c,b), choosing a, b, c in any way from the variables x1,x2,x3. Try to show that f(xi,xj)=-f(xj,xi) is also true, so f(xi,xj)=0 for x1,x2,x3,x4. ehild |
| Jul20-12, 08:50 AM | #14 |
For chet and ehild: it seems you are wrong. Well, let's enumerate our eqns:
[tex]\begin{align} & \sqrt{\frac{x_{1}^{2}x_{4}^{2}}{4}-{{({{x}_{1}}-{{x}_{4}})}^{2}}}-\sqrt{\frac{x_{1}^{2}x_{3}^{2}}{4}-{{({{x}_{1}}-{{x}_{3}})}^{2}}}=\sqrt{\frac{x_{3}^{2}x_{4}^{2}}{4}-{{({{x}_{3}}-{{x}_{4}})}^{2}}}\ \ \ \ \ (1) \\ & \sqrt{\frac{x_{1}^{2}x_{4}^{2}}{4}-{{({{x}_{1}}-{{x}_{4}})}^{2}}}-\sqrt{\frac{x_{1}^{2}x_{2}^{2}}{4}-{{({{x}_{1}}-{{x}_{2}})}^{2}}}=\sqrt{\frac{x_{2}^{2}x_{4}^{2}}{4}-{{({{x}_{2}}-{{x}_{4}})}^{2}}}\ \ \ \ \ (2) \\ & \sqrt{\frac{x_{1}^{2}x_{3}^{2}}{4}-{{({{x}_{1}}-{{x}_{3}})}^{2}}}-\sqrt{\frac{x_{1}^{2}x_{2}^{2}}{4}-{{({{x}_{1}}-{{x}_{2}})}^{2}}}=\sqrt{\frac{x_{2}^{2}x_{3}^{2}}{4}-{{({{x}_{2}}-{{x}_{3}})}^{2}}}\ \ \ \ \ (3) \\ \end{align}[/tex] and introduce function [tex]f\left( {{x}_{i}},{{x}_{j}} \right)=\sqrt{\frac{x_{i}^{2}x_{j}^{2}}{4}-{{({{x}_{i}}-{{x}_{j}})}^{2}}}[/tex] with obvious property [tex]f\left( {{x}_{i}},{{x}_{j}} \right)=f\left( {{x}_{j}},{{x}_{i}} \right)\ \ \ \ \ (*)[/tex] then our system will have a form of [tex] \begin{align} & f\left( {{x}_{1}},{{x}_{4}} \right)-f\left( {{x}_{1}},{{x}_{3}} \right)=f\left( {{x}_{3}},{{x}_{4}} \right)\ \ \ \ \ ({1}') \\ & f\left( {{x}_{1}},{{x}_{4}} \right)-f\left( {{x}_{1}},{{x}_{2}} \right)=f\left( {{x}_{2}},{{x}_{4}} \right)\ \ \ \ \ ({2}') \\ & f\left( {{x}_{1}},{{x}_{3}} \right)-f\left( {{x}_{1}},{{x}_{2}} \right)=f\left( {{x}_{2}},{{x}_{3}} \right)\ \ \ \ \ ({3}') \\ \end{align}[/tex] |
| Jul20-12, 09:32 AM | #15 |
Recognitions:
Well, not all goals can be achieved.
Subtracting 2' from 1' and comparing it with 3': [tex]f(x_1,x_2)-f(x_1,x_3)=f(x_3 ,x_4)-f(x_2,x_4)=-f(x_2, x_3)[/tex] Rearranging : [tex]f(x_2, x_4)-f(x_2,x_3)=f(x_3 ,x_4)[/tex] You can get similar relation between any pair of the xi-s: Let be a, b, c any different xi-s. f(a,b)-f(a,c)=f(c,b), but also f(b,c)-f(b,a)=f(a,c), or f(b,a)+f(a,c)=f(b,c) As f(a,b)=f(b,a) and f(b,c)=f(c,b), f(a,b)+f(a,c)=f(b,c), that is f(a,c)=-f(a,c) I hope my derivation is correct... ehild |
| Jul20-12, 10:51 AM | #16 |
| Jul20-12, 11:32 AM | #17 |
Recognitions:
RGV |
| New Reply |
Similar discussions for: System of three equations and four variables
| Reproduce a solution set to a linear system with 2 equations and 8 variables | Precalculus Mathematics Homework | 6 | ||
| Solving for variables using 3 different equations (simultaneous equations) | Precalculus Mathematics Homework | 1 | ||
| Define coefficients for system of equations with 3 variables | Calculus & Beyond Homework | 13 | ||
| Complex conjugate variables as independent variables in polynomial equations | Linear & Abstract Algebra | 0 | ||
| Linear Algebra - System of 2 Equations with 3 Variables--possible? | Calculus & Beyond Homework | 4 | ||
