| New Reply |
Optical Radiation |
Share Thread | Thread Tools |
| Jul19-12, 02:48 AM | #1 |
Optical Radiation
Assume you have a sinusoidal 500THz function generator and assume you have a compatible antenna. If you feed the signal to your antenna, is optical phenomena observable ?
| Jul19-12, 03:22 AM | #2 |
| Jul19-12, 03:26 AM | #3 |
Time-varying electric currents flowing through a conductor radiates electromagnetic fields at the same frequency. If a 500THz function generator (electrical signal output) is fed to a conductor at appropriate size, can human eye observe the emission ? |
| Jul19-12, 04:17 AM | #4 |
Optical Radiation
y33t, sorry, I jumped to some conclusion. This is from Wikipedia:
"Terahertz radiation is a region of the spectrum between far infrared and microwaves. Until recently, the range was rarely studied and few sources existed for microwave energy at the high end of the band (sub-millimeter waves or so-called terahertz waves), but applications such as imaging and communications are now appearing. Scientists are also looking to apply terahertz technology in the armed forces, where high-frequency waves might be directed at enemy troops to incapacitate their electronic equipment. [15] http://en.wikipedia.org/wiki/Electromagnetic_spectrum [15] The interaction between high-intensity, ultra-short laser pulses and plasmas leads to the emission of coherent, short-pulse radiation at terahertz frequencies. A device is developed that can use the short-pulse radiation at terahertz frequencies to deactivate any electronic systems many miles away and create a virtual shield for any advancing army, navy or air force. http://www.indiadaily.com/editorial/1803.asp |
| Jul19-12, 08:06 AM | #5 |
| Jul19-12, 08:13 AM | #6 |
Mentor
| Jul19-12, 03:14 PM | #7 |
| Jul29-12, 01:00 PM | #8 |
| Jul29-12, 01:03 PM | #9 |
What would be the interpretation from wave-particle duality approach in this phenomena ? Will there be photons ? |
| Jul29-12, 02:18 PM | #10 |
| Jul29-12, 02:36 PM | #11 |
| Jul29-12, 03:42 PM | #12 |
Mentor
You will see a spot of light, even with the best microscopes. |
| Jul29-12, 03:53 PM | #13 |
| Jul29-12, 04:57 PM | #14 |
There must be some sort of limit based on the mean time between collisions of electrons in a conducting wire. I don't see how you could make electrons oscillate with such speed if they don't have time to actually interact with one another?
Solid state physics is definitely my weak point but I'm struggling to come up with a fundamental reason why this shouldn't be possible. |
| Jul29-12, 06:07 PM | #15 |
Y33t, sevgili dostum,
I’m not sure this will enlighten you. I am slightly confused by your questions. You have proposed the application of a 500Terahertz (THz) signal to an antenna of 500 nanometer (nm) in length. When I calculate the wavelength of 500 THz EM radiation signal I get about 600 nm. This is called submillimeter radiation (in astronomy) and is not visible to the human eye. Furthermore, when I calculate the frequency of EM radiation of 500 nm I get about 600 THz. This is what’s known as “blue-green visible light”. I am sure you have already seen seven different types of Terahertz radiation generators at: http://en.wikipedia.org/wiki/Terahertz_radiation None of these THz generators produce radiation that is visible. I may be totally wrong with my above calculations because I am not schooled in quantum optics. Will you please try to help me understand your experiment? Cheers, Bobbywhy |
| Jul29-12, 06:28 PM | #16 |
Mentor
Bobbywhy: 600µm is sub-millimeter, and 1000 times longer than 600nm. 600nm is similar to 500nm, just a different color (the visible range is roughly 400-800nm).
THz generators generate ~1THz, not 500. |
| Jul29-12, 06:31 PM | #17 |
mfb, thank you for the clarifying explanations.
| New Reply |
| Thread Tools | |
Similar Threads for: Optical Radiation
| Optical Instruments I: Optical Element | Introductory Physics Homework | 3 | ||
| Thermal radiation and optical opacity | General Physics | 0 | ||
| reason for optical activity(of optical isomers) | Chemistry | 1 | ||
