| New Reply |
Raindrops and a car problem |
Share Thread | Thread Tools |
| Jul19-12, 04:46 PM | #1 |
A car travels to east with 50 km/h. It's rainning vertically in relation to the Earth. The raindrops on the lateral windows of the car make a 60 degree angle with the vertical. Determine the velocity of the raindrops in relation to: a) The Earth b) The car 2. Relevant equations I really don't know what to do here xD 3. The attempt at a solution I really don't know what to do here xD |
| Jul19-12, 05:28 PM | #2 |
Hi. This is a relative velocity problem. I'll try to get you started.
Take toward the right on a sheet of paper to represent east and toward the top of the paper as representing vertically upward from the earth. Draw a vector representing the velocity vector of the car relative to the earth:[itex]\vec{V}[/itex]C/E Draw a vector representing the velocity of the rain relative to the earth: [itex]\vec{V}[/itex]R/E Draw a vector representing the velocity of the rain relative to the car: [itex]\vec{V}[/itex]R/C Which two of these vectors when added together will equal the third vector? |
| Jul19-12, 05:44 PM | #3 |
VC/E plus VR/E? That's equal to the 3rd vector
| Jul19-12, 05:52 PM | #4 |
Mentor
Raindrops and a car problemHow are [itex]\displaystyle \vec{v}_{C/E}\,,\ \vec{v}_{R/E}\,,\text{ and }\vec{v}_{R/C}[/itex] related? |
| Jul19-12, 07:01 PM | #5 |
Vr/c = Vc/e + Vr/e
so by that logic Vr/c = 50/sin(60) and of course Vr/e = Vr/c cos(60) = (50cos(60))/sin(60) and thats the answer by this logic right? |
| Jul19-12, 10:19 PM | #6 |
Can you see the correct relationship? |
| Jul19-12, 10:57 PM | #7 |
So from what I draw I understood that the actual velocity diagram is given by Vc/e = Vr/e + Vr/c but besides that the results that I obtained before were right
| Jul19-12, 11:18 PM | #8 |
Vr/e = velocity of rain with respect to the earth which is a vector pointing straight down. Vr/c = velocity of rain with respect to the car which is a vector pointing down and to the left (i.e., down and toward the west). If I place these vectors "head-to-tail" to add them, I get a resultant vector that points down and to the left (but more steeply downward than Vr/c). This doesn't agree with Vc/e which is the velocity of the car with respect to the earth and points horizontally toward the right. |
| Jul19-12, 11:31 PM | #9 |
So the Vr/e + Vc/e = Vr/c
| Jul19-12, 11:32 PM | #10 |
There's a general rule for setting up correct relative velocity equations. Suppose you have three objects a, b, and c which move relatively to one another. A correct equation would be
Va/c = Va/b + Vb/c Another correct relation would be Vb/a = Vb/c + Vc/a The general rule is that whatever subscript appears first on the left side of the equation is also the first subscript on the right side of the equation. The last subscript on the left side is also the last subscript on the right side. Whatever subscript does not appear on the left side will appear on the right as "sandwiched between" the first and last subscripts. Thus in the first equation above, "a" appears first on both sides of the equation and "c" appears last on both sides. "b" is sandwiched between "a" and "c" on the right side. See if this can help you set up a correct equation for the velocities in your problem. |
| Jul19-12, 11:39 PM | #11 |
Another rule that is often useful is Va/b = -Vb/a. (You might not need this rule to solve the particular problem you are working on now, but it might come in handy in other problems.)
Example, if a car is moving toward the east at 50 mph relative to the earth, then the earth would be moving at 50 mph toward the west relative to the car: Vc/e = -Ve/c |
| Jul19-12, 11:42 PM | #12 |
Vr/e=Vr/c + Vc/e....
Seriously I'm feeling so stupid right I have an exam in 3h hours and I'm feeling like a don't know a thing! |
| Jul19-12, 11:42 PM | #13 |
Either way thanks for the help you've been given me
| Jul19-12, 11:46 PM | #14 |
Good luck with your exam. |
| Jul20-12, 12:13 AM | #15 |
I guess the raindrops must be at terminal velocity.
| New Reply |
| Thread Tools | |
Similar Threads for: Raindrops and a car problem
| speed of raindrops | Introductory Physics Homework | 5 | ||
| Raindrops | Introductory Physics Homework | 2 | ||
| Raindrops | Introductory Physics Homework | 1 | ||
| Raindrops and Gravity | Special & General Relativity | 9 | ||
| Raindrops | Introductory Physics Homework | 4 | ||
