New Reply
Find Solution 4*(x^2)*y"+y=0, y(-1)=2, y'(-1)=0
Share Thread Thread Tools
Jul21-12, 08:58 AM   #1
Not even sure where to start on this one???
Is this a series solution problem?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Jul21-12, 09:29 AM   #2
Try a solution of the form x^n
Jul21-12, 09:33 AM   #3
x^n?, does that mean y=a(n)x^n, leading to y'=n*a(n)*x^(n-1), y"=n*(n-1)*a(n)*x(n-2), then substitute?
Jul21-12, 10:00 AM   #4
Well, you can throw in an a(n) if you want but once you do your substitution you'll see that it cancels out. That said, the a(n) is important as it is a constant that will be determined once you use your boundary conditions.
Basically, set y = a(n)x^n and find which values of n will make 4*(x^2)*y'' + y equal zero.
Jul21-12, 10:08 AM   #5
I end up with 4*x^2*(sum(n=0))(n+2)*(n+1)*a(n-2)*(x^n)+(sum(n=0))a(n)*(x^n)
I'm working toward the recurance relation, correct?
What about the 4*x^2 for the first summation?
Jul21-12, 10:42 AM   #6
You're not working towards a recurrence relation, let's see if we can get away with something easier!
Literally just write y = x^n
Then 4*(x^2)*y'' + y = 4n(n-1)x^n + x^n = [4n^2 - 4n + 1]x^n = ([2n - 1]^2)x^n
So we know that n=1/2 will give us a working solution i.e. y = A*x^(1/2)
Unfortunately, we need two degrees of freedom and we just have one. Luckily, we know how to deal with resonance of this form as we know that y = B*x^(1/2)*ln(x) will be a solution.
Thus, our general solution is y = x^(1/2)*[A + Bln(x)]
New Reply
Tags
diff eg
Thread Tools
Similar Threads for: Find Solution 4*(x^2)*y"+y=0, y(-1)=2, y'(-1)=0
Thread Forum Replies
Cannot do the "find" command with "undefined variable" ? Calculus & Beyond Homework 0
Can anyone help me to find out the definition of "carrier swing"&"deviation ratio"? General Physics 1
How can I find a solution valid for "all" cases? Linear & Abstract Algebra 5
Is it common to find the "applied" explanations more confusing than the "theoretical" Academic Guidance 1
Find values of K for which k has no solution, many solutions a unique solution Precalculus Mathematics Homework 3
