New Reply
Impact force (distance & time after impact unknown)
Share Thread
Jul22-12, 01:51 PM   #1
A vehicle falls 20 mm back onto a smooth steel track after going over a bump. It has polyurethane wheels. Young's modulus is known for both wheels and track materials. What is the force exerted by the vehicle onto the track as it lands?
2. Relevant equations
F = mdv/dt
KE = (ma^2)/2
F = KE/d
3. The attempt at a solution
I've looked long and hard for a solution to this but all I found were equations (such as the ones above) that require either a pre-known time value for the collision or a pre-known value for distance travelled after impact.
How can an impact force be calculated simply by knowing material properties, mass of falling object, and distance of fall?
Thanks.
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jul25-12, 09:05 AM   #2
I'm not familiar with Youngs Modulus but since you haven't had an answer...
Presumably the youngs modulus can be used to work out an equivalent spring constant for the combined wheel/track. You know the energy compressing it so you can work out the distance it's compressed???
Jul26-12, 07:51 AM   #3
Thanks. I've since found a couple of equations for impact stress and deflection, based on strain energy.
New Reply
Similar Threads for: Impact force (distance & time after impact unknown)
Thread Forum Replies
How do I determine Force or time from an impact? Classical Physics 6
calculating distance from force and impact Classical Physics 2
Creating a vert. drop impact that is equivalent to a faster, but lighter hor. impact General Physics 5
[SOLVED] Calculate Average Force by finding Impulse over Impact Time Introductory Physics Homework 6
