New Reply
Carbon Content decrease after Cold-forging process?
Share Thread Thread Tools
Jul25-12, 10:30 AM   #1
Hi guys,
I've come across an abnormality at work with regards to Carbon Content.
The raw material used was 1010 CHQ which should have a carbon content of 0.08 - 0.13.
However after going through a cold-forging process, we tested the final product and found that the Carbon Content decreased to 0.041.
How did this happen? Is it possible? Can someone explain?
Really stumped at this stage.
Cheers,
Daniel.
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Researchers use light projector and single-pixel detectors to create 3-D images
>> GPS solution provides 3-minute tsunami alerts
>> Single-pixel power: Scientists make 3-D images without a camera
Aug24-12, 11:55 AM   #2
No explanation. That sounds astounding to me.
Maybe there was some segregation and the tiny place where you measured was chosen unluckily?
Oct18-12, 06:57 AM   #3
segregation may lead to C atoms migrating to surface of the material.
But this should not be a problem unless the material is heated for a long time.
If heated for a long time and tested after heating inside the material, the result of yours seems to be acceptable.
New Reply
Thread Tools
Similar Threads for: Carbon Content decrease after Cold-forging process?
Thread Forum Replies
Heating Requirements for Forging Process Engineering Systems & Design 0
The carbon content of a good samari sword Chemistry 3
carbon content in steel and corrosion Biology, Chemistry & Other Homework 1
Effect of Carbon Content in Steel Biology, Chemistry & Other Homework 2
Effect of Mn content in medium Carbon steel Materials & Chemical Engineering 0
