| New Reply |
Double Integration using u-substitution |
Share Thread | Thread Tools |
| Jul25-12, 12:03 PM | #1 |
Hey guys, so we're going over multiple integration in Calc III, and I'm having trouble with the more complex problems. ∬ √(x + 4y) dxdy, where R = [0, 1] x [2, 3] So it's 0 to 1 on the outside integral, 2 to 3 on the inside integral, of sqrt(x+4y) dxdy. 2. Relevant equations Iterated Integrals u-substitution 3. The attempt at a solution I solved the previous double integration problem, but using u-substitution in two variables is throwing me off. I would assume that, u = x + 4y du = 1 dx (since we're integrating with respect to x first, and holding y as a constant, so x becomes 1 and 4y drops out). So du = dx = ∬ √(u) du = ∫(0 to 1) [(2u^(3/2))/3] (2 to 3) dy = ∫(0 to 1) (((2(3 + 4y)^(3/2))/3) - (2(2 + 4y)^(3/2))/3)) dy And this is where I stopped since this seems way overly complicated, and I feel like I did something wrong. My main problem: Change of variables: If I want to change the integral variables, i.e. 2 to 3, I know in the single variable case that you use the u equation. But here, u = x + 4y, it has two variables. I only have 2 and 3 so do I just plug that into the x and completely ignore anything attached to a y? Pretend the y isn't there? It doesn't make much sense to me. u-substitution in general, with multiple integration: I'm not sure if I'm going through the process after that correctly, either. If I could figure this out, and know the correct way to do these kinds of problems in general, I could do much more, but for now I'm stuck on all of these problems since they're mostly similar. Thank you very much for any help or input! |
| Jul25-12, 12:18 PM | #2 |
Correct me if this is wrong, the point where you stopped is
[itex]\int^{0}_{1}[/itex] [[itex]\frac{(3 + 4y)^{3/2}}{3/2}[/itex] - [itex]\frac{(2 + 4y)^{3/2}}{3/2}[/itex]] dy You are on the right track. Use the same technique as the one used for x-integration. |
| Jul25-12, 12:20 PM | #3 |
Yes, you're being way too complicated. If you first integrate wrt x, just treat the 4y as some constant, so you're integrating sqrt(X+C).
| Jul25-12, 12:27 PM | #4 |
@Sourabh. Sure thing, it just looked... wrong, but I'll take a crack at continuing.
@daveb: I was under the impression I needed u-substitution for more than one value under a square root? Or does it just become (2(x+C)^(3/2))/3)? Also: Could someone just shed some light on my change of variables question? That would clear things up a good deal. |
| Jul25-12, 12:31 PM | #5 |
It'd be better if you rephrase your "Change of variables" question, making it more specific. :)
| Jul25-12, 12:41 PM | #6 |
Single variable substitution: Let's say you have some arbitrary integration problem from 2 to 4, of √(x^2 + x). Here, u = x^2 + x du = 2x + 1 dx dx = du/2x + 1 And so, instead of 2 to 4, the bounds become: (2)^2 + (2) = 6 (4)^2 + 4 = 20 So the problem becomes: integrate, from 6 to 20, (sqrt(u)) du/2x+1, yes? So I understand changing the bounds in those cases, but for example, in this problem, where u = x + 4y - I don't know what to do with the y. If I follow the same method, with bounds 2 to 3, the bounds would become: 2 + 4y to 3 + 4y And I'm not sure how to handle the y. I don't know how to change the bounds using u-sub with multiple variables. |
| Jul25-12, 12:48 PM | #7 |
| Jul25-12, 12:57 PM | #8 |
I literally just completely drop the y? Ignore it? Say, u = 2x + xy + y, and normal bounds are from 2 to 4 Then, change of bounds: u = 2(2) + 2 and 2(4) + 4 Making it 6 to 12? Again just pretending the y isn't there even though it is attached to the x as well? |
| Jul25-12, 01:04 PM | #9 |
Some examples: 1. u = 42x + y; x goes from 0 to 1 => u goes from y to 42 + y. 2. u = 42x + 5; x goes from 0 to 1 => u goes from 5 to 47. 2. u = x + xy + y2; x goes from 4 to 6 => u goes from 4 + 4y + y2 to 6 + 6y + y2. |
| Jul25-12, 01:05 PM | #10 |
So they become variable bounds. Got it. Thanks so much for the help and patience Sourabh!
| Jul25-12, 01:09 PM | #11 |
No problem :)
| Jul25-12, 01:33 PM | #12 |
Hey guys, I'm sorry to bring the same problem up again, but my answer is lacking two entire terms and I'm not sure what I'm omitting.
Problem: ∬ √(x + 4y) dxdy, where R = [0, 1] x [2, 3] Solution attempt: I would assume that, u = x + 4y du = 1 dx (since we're integrating with respect to x first, and holding y as a constant, so x becomes 1 and 4y drops out). So du = dx = ∬ √(u) du = ∫(0 to 1) [(2u^(3/2))/3] (2 to 3) dy = ∫(0 to 1) (((2(3 + 4y)^(3/2))/3) - (2(2 + 4y)^(3/2))/3)) dy Moving on... u = 3 + 4y, du = 4 dy, dy = du/4 Bounds (0 to 1) become 3 to 7: = ∫(3 to 7) (2u^(3/2))/3) - (2u^(3/2))/3) du/4 = 1/4[(4u^(5/2)/15) - (4u^(5/2)/15)] from 3 to 7 ((1/4) cancels out with both terms on inside so: ) = (7^(5/3)/15) - (3^(5/2)/15) = 1/15(7^(5/2) - 3^(5/2)) And done. However, the back of the book disagrees with me, stating the answer as: 1/15(7^(5/2) - 6^(5/2) - 3^(5/2) + 2^(5/2)) And I looked back through my work and I just don't see where that second and fourth term are coming from. Is there a step or two I'm completely missing? |
| Jul26-12, 09:25 AM | #13 |
If you're integrating [0,1]x[2,3], your bounds for x range from 0 to 2 and y ranges from 1to 3. You have the limits of integration wrong.
| Jul29-12, 12:58 PM | #14 |
| New Reply |
| Tags |
| calculus, calculus 3, double integration, u-substitution |
| Thread Tools | |
Similar Threads for: Double Integration using u-substitution
| Integration by substitution (and esp. Weierstrass' substitution) | Calculus | 2 | ||
| Integration - u substitution problem (Integration by parts?) | Calculus & Beyond Homework | 7 | ||
| Substitution for double integrals | Calculus & Beyond Homework | 1 | ||
| Double Integral Substitution | Calculus & Beyond Homework | 6 | ||
| Integration, trig with double substitution | Calculus & Beyond Homework | 7 | ||
