What is the limit of classical electrodynamics?
The interaction between an electron and an electromagnetic wave is governed by classical electrodynamics until the influence of single photons becomes significant, as seen in phenomena like the photoelectric effect. In such cases, classical electrodynamics fails to provide accurate predictions. However, when dealing with many photons, classical theories remain valid, particularly in scenarios involving nearly static fields or long-wavelength radiation, and occasionally with high-intensity visible light.
  • Understanding of classical electrodynamics principles
  • Familiarity with the photoelectric effect
  • Knowledge of photon interactions with matter
  • Basic concepts of electromagnetic wave behavior
  • Research the limitations of classical electrodynamics in quantum scenarios
  • Study the photoelectric effect and its implications on classical theories
  • Explore quantum electrodynamics (QED) for a deeper understanding of photon-electron interactions
  • Investigate the effects of high-intensity electromagnetic fields on electron behavior
Physicists, electrical engineers, and students studying advanced electromagnetism or quantum mechanics will benefit from this discussion.
KristallIsa
Hello everyone,
I was wondering about the following question:
Under what condition(s) could one say that the interaction between an electron and an electromagnetic wave is not governed anymore by the laws of classical electrodynamics?
I would also be glad if someone could point out any good references on this topic. I've been searching for some time already but with not much luck...!
Thank you very much.
If the interaction of single photons with electrons becomes significant (for example at the photoelectric effect), classical ED will give wrong predictions. In the limit of many photons, it should be fine. This is usually the case with (nearly) static fields or radiation with long wavelengths, and sometimes with visible light of extreme intensity.
  • · Replies 30 ·
