Pathway to High P and T from Very Low P and T
The discussion focuses on transitioning a block of ice (20 cm³) from very low pressure (10-8 kPa) and low temperature (100 K) to high temperature (approximately 500 K) and high pressure (around 18 MPa) within a constant volume box (50 cm³) under a constant heat flux. The initial phase transition involves heating the ice until it reaches the sublimation line, where it converts directly to vapor. The challenge lies in quantifying the pressure and temperature changes after sublimation while maintaining constant volume and heat input, particularly in the context of ideal gas behavior and the P-T diagram.
  • Understanding of phase transitions and the P-T diagram.
  • Knowledge of thermodynamics, particularly the ideal gas law.
  • Familiarity with sublimation and the properties of water at varying temperatures and pressures.
  • Experience with heat transfer concepts and constant volume systems.
  • Research the phase transition regimes of water, focusing on sublimation and boiling points.
  • Study the ideal gas law and its application in constant volume scenarios.
  • Examine the P-T diagrams for water and other substances to understand the behavior during phase changes.
  • Explore thermodynamic calculations for energy requirements during phase transitions.
Researchers, physicists, and engineers involved in thermodynamics, particularly those studying phase transitions and heat transfer in constrained environments.
neutrons
Hi all,
There is a block of ice (say 20 cm^3) sitting inside a box (50cm^3, constant volume) at very low P and low T (say P = 10^(-8) kPa and T = 100 K ... roughly ambient moon P and T).
There is a constant heat flux incident on the box. I want a 'path-way' (explicit phase transition regimes etc) that will take this ice block to high T (~ 500 K) and high P (~ 18 MPa), and quantify energy requirement in each step. The heat source is infinite. Please make any other assumption that may prove helpful.
My approach:
The given P and T is well below the triple point. If I heat the ice, it will increase its T under the same initial P. Once it hits the sublimation line, the energy input will convert it directly to vapor (under constant P, is this assumption valid?) .
Now, after everything is vapor, if I continue heating, I am not sure how to quantify the path-way in the P-T diagram. (Assuming ideal gas under constant V... P has linear relationship with T but I can't tell anything about the slope). How does the P and T change now (after sublimation) under constant volume and constant heat source?
Please help me quantify this.
Many thanks !
(I was looking at XSteam and there is no data at low P and T.)
Not sure your system will be that well behaved.
The ice will shrink as it melts, so there will be an interval where you have liquid water and water vapor in your box. That will put a kink in your P-T diagram between 273 and 277 K, with another one at 373+ K when the water turns to steam.
  • · Replies 0 ·
