| New Reply |
density of a star cluster |
Share Thread | Thread Tools |
| Jul25-12, 08:34 PM | #1 |
A large, spherically symmetric collection of point particles of mass m move in circular orbits about a common center each with the same kinetic energy. If the only force acting is the mutual gravitational attraction of the particles, find the particle density (in the continuum limit) as a function of r from the center in order that the density remain constant in time. 2. Relevant equations [itex]F=\frac{GMm}{R^{2}}[/itex] ,where M is the total mass. [itex]\frac{v^{2}}{R}=\frac{GM}{R^{2}}[/itex] 3. The attempt at a solution [itex]\frac{F}{m}=\frac{GM}{R^{2}}[/itex] [itex]\frac{4\pi F}{m}=\frac{4\pi GM}{R^{2}}[/itex] [itex]dM=\rho(R)R^{2}dR4\pi[/itex] [itex]dM=\frac{v^{2}}{G}dR[/itex] [itex]\rho(R)=\frac{v^{2}}{4\pi GR^{2}}[/itex] [itex]\frac{1}{2}mv^{2}=\frac{GMm}{r}[/itex] solve for v and substitute into prev. equation. [itex]\rho(R)=\frac{GM}{2\pi R^{3}}[/itex] Is this looking ok? Thanks for the help |
| Jul26-12, 07:41 AM | #2 |
I'm not sure if I understand the question. I would imagine that if you have a continuous distribution of stuff on spherical orbits, then the density is always constant in time. In order to find a unique density, you need to specify the velocity of each shell, v(R).
For example, suppose you have v(R) = constant. Then you'd find [tex] \frac{v^2}{R} = \frac{GM}{R^2} \rightarrow M \propto v^2 R \propto R [/tex] and therefore dM/dR = constant... Then [tex] \frac{dM}{dR} = 4 \pi R^2 \rho \rightarrow \rho \propto R^{-2}. [/tex] On the other hand, suppose you want your system to rotate like a rigid body, with [itex] v \propto R [/itex]. Then [tex] M \propto R^3 [/tex] and ρ=constant. Also having [itex]\rho \propto R^{-3}[/itex] seems really suspicious to me, as this means that M diverges if you integrate to R=0. |
| New Reply |
| Thread Tools | |
Similar Threads for: density of a star cluster
| Star Cluster Within Self Schwarzschild Radius | Astrophysics | 5 | ||
| Is our sun part of a star cluster? | General Astronomy | 5 | ||
| Show that 1/2mv^2 = 3/2kT for a star cluster | Introductory Physics Homework | 6 | ||
| Distance of Star Cluster | Introductory Physics Homework | 0 | ||
| Star Cluster Gravity | General Astronomy | 4 | ||
