Complex power/power factor calculations
The discussion focuses on complex power calculations in electrical engineering, specifically using the formula S = VI* / 2, where S represents complex power, V is voltage, and I is current. Key calculations include determining the power factor angles using arccos, with values of 36.86 degrees for a power factor of 0.8 and 41.4 degrees for a power factor of 0.75. The user seeks clarification on whether a load given in kW can be assumed to be purely resistive and how to express the complex power of a kVA load. Additionally, the user explores the definition of system power and the application of Kirchhoff's Current Law (KCL) and Kirchhoff's Voltage Law (KVL) in their calculations.
  • Understanding of complex power calculations in AC circuits
  • Familiarity with power factor and its implications
  • Knowledge of Kirchhoff's Current Law (KCL) and Kirchhoff's Voltage Law (KVL)
  • Ability to perform trigonometric calculations, specifically arccos
  • Learn about calculating reactive power using the formula Q = P * tan(θ)
  • Study the implications of power factor on circuit design and efficiency
  • Explore the use of phasors in AC circuit analysis
  • Investigate the relationship between voltage, current, and impedance in AC circuits
Electrical engineering students, professionals working with AC circuits, and anyone involved in power system analysis and optimization.
i_am_stupid
(old exam question attached)
Complex power: S = VI* / 2 = P + jQ where P is the average power and Q is the reactive power
Magnitude of complex power |S| = Vmax*Imax/2
V = ZI
We can calculate θv - θi for each load by using arccos(power factor).
arccos 0.8 = 36.86 degrees
arccos 0.75 = 41.4 degrees
Because I'm fairly new to these types of problems I need to make sure I'm understanding this correctly before I can go any further:
- The first load is given in kW and the other is given in kVA. Does this mean that we can assume that the first load is purely resistive?
- Can I go ahead and express the complex power of the second load as 40/_41.4 -> 7.5 + 6.6j?
I'm thinking that the answers to these questions will indicate what I should do next.
Regarding part b), how exactly is system power defined? Is it the sum of the power delivered to all of the elements? If so, could I simply add the complex power delivered to the impedance Zs to the complex power delivered to both loads?
Thanks for any help you guys can offer!
EDIT: I just realized I have enough information to calculate the current flowing through the kVA load using S = VI* / 2. Alone, this doesn't help much, but by following a similar procedure for the first load (after determining what the complex power is, exactly) I can apply KCL and determine the current through the branch with the impedance (i1 + i2 = i3).
EDIT 2: Another thought - could I find the current through the impedance directly by using the complex power delivered to both loads as Stotal = S1 + S2 = 40 + (7.5 + 6.6j) and S = VI* / 2? This would solve part a), after finding the voltage of the impedance Zs and using KVL in the leftmost mesh.
First load is not pure resisitive as power factor is not [itex]1[/itex]:
[itex]\begin{cases}P_1=40\,kW\\PF=0.8\end{cases} \Rightarrow Q_1=P_1\frac{\sqrt{1-(PF)^2}}{PF}=30\,kVA\\<br /> \begin{cases}Q_2=40\,kVA\\PF=0.75\end{cases} \Rightarrow P_2=Q_2\frac{PF}{\sqrt{1-(PF)^2}}=\frac{120}{\sqrt{7}}\,kW[/itex]
I think [itex]V=220\angle 0[/itex] means [itex]V_{rms}=220[/itex] not [itex]V_{max}=220[/itex] so [itex]S=VI^*[/itex]
  • · Replies 18 ·
  • · Replies 18 ·
