| New Reply |
Potential at the end of a rod |
Share Thread | Thread Tools |
| Jul26-12, 09:50 PM | #1 |
Hi all!
So I've been doing some work with potential calculations, and I seem to be running into a bit of trouble with figuring out how to think about the potential due to a rod at the very edge of it. Imagine an insulating rod with charge Q is placed along the positive x-axis, with its left end at the origin. I can calculate the potential anywhere on the y-axis, and anywhere on the negative x-axis quite easily. But when I try to take the limiting case of a point at the left end of the rod, something strange happens: I can let y approach 0, or x approach 0 in either of the expressions, and I find that the potential at the end of the rod is infinite. This is because the potential contains the natural log. I contend that this doesn't make physical sense! You see, what if I had instead charged the rod to a charge Q+q. If the potential when charge Q is already on the rod is infinite at the end, how can I place the extra bit q on the rod? But I know that Q can have any value, which means I should be able to make Q large enough that it includes that extra bit, had I wanted to from the start. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jul26-12, 10:41 PM | #2 |
I don't understand. Why are you trying to find the potential between 2 points on the rod if the rod is charged with Q? Wouldn't there be 0 potential?
| Jul26-12, 10:45 PM | #3 |
I think not- for one, it's not a conductor, and for two this is relative to a 0 potential at infinity, the way that I'm thinking about it (I'm integrating dV over the entire rod to get V, but this all presupposes that V=0 at infinite distances).
| Jul26-12, 11:01 PM | #4 |
| Jul27-12, 12:32 AM | #5 |
Recognitions:
To avoid this you need to make it at least 2 dimensional, but might as well make it 3. 5.8.7 in http://www.astro.uvic.ca/~tatum/celmechs/celm5.pdf derives the (gravitational) potential due to a uniform solid cylinder. |
| New Reply |
| Thread Tools | |
Similar Threads for: Potential at the end of a rod
| Electrochemical potential, chemical potential and Fermi levels. Ashcroft is confusing | Atomic, Solid State, Comp. Physics | 0 | ||
| Potential step with infinite potential barrier (D.A.B Miller problem 2.8.6) | Advanced Physics Homework | 8 | ||
| Describing chemical potential in Galvanic cell using Coulomb Force/Electric Potential | Classical Physics | 0 | ||
| Electric Potential Difference Question (Parallel plates, higher potential) | Introductory Physics Homework | 1 | ||
| Electric potential, potential difference, and potential energy | Introductory Physics Homework | 2 | ||
