New Reply
Flow rate (CFM) in a different inlet are & outlet area
Share Thread Thread Tools
Jul27-12, 08:26 AM   #1
Hello,
Here are the knowns:
Inlet open area = 17 inches^2
Outlet open area = 30 inches^2
Internal Fans = 270 cfm (3 fans @ 90 cfm each)
What is the CFM through the system and what's the equations used to figure this out?
Thanks a ton!
John
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jul27-12, 08:49 AM   #2
Mentor
The answer appears to be given in the problem statement: 270 cfm.
Jul27-12, 08:53 AM   #3
The fan spec is 90cfm per fan. That doesn't mean that 270cfm (3 fans) is what will exhaust out the rear of the unit. If I have a huge fan inside a box and a very little inlet or outlet, the fan will be choked and pressure will build due to the open air restriction.
Jul27-12, 10:07 AM   #4
Mentor
You'll need to look at fan curves and estimate pressure drop through your system then.
Do you have a sketch you can upload?
New Reply
Tags
flow rate
Thread Tools
Similar Threads for: Flow rate (CFM) in a different inlet are & outlet area
Thread Forum Replies
Designing a hot water 'element' to melt honey-calculating flow rate and surface area Engineering Systems & Design 4
Flow rate depending on pressure with constant inlet rate. Engineering, Comp Sci, & Technology Homework 1
COMSOL: Periodic inlet flow rate in a pipe Computing & Technology 1
COMSOL periodic BC inlet flow rate Engineering Systems & Design 0
Thermodynamics: Open system: outlet but no inlet Classical Physics 4
