CFM calculation with a known fan and different inlet and outlet areas
The discussion centers on calculating the CFM (Cubic Feet per Minute) in a system with specific inlet and outlet areas. The known parameters include an inlet open area of 17 inches², an outlet open area of 30 inches², and three internal fans rated at 90 CFM each, totaling 270 CFM. The consensus is that while the inlet area is relatively small, it is feasible for the fans to achieve the rated CFM, but additional factors such as pressure dynamics and airflow resistance must be considered to determine if the fans will be choked.
  • Understanding of CFM calculations and airflow dynamics
  • Familiarity with fan specifications and performance metrics
  • Knowledge of pressure differentials in HVAC systems
  • Basic principles of fluid mechanics
  • Research "CFM calculation methods for HVAC systems"
  • Explore "impact of inlet and outlet area on airflow efficiency"
  • Learn about "pressure drop calculations in duct systems"
  • Investigate "fan performance curves and system resistance"
Engineers, HVAC professionals, and anyone involved in designing or optimizing airflow systems will benefit from this discussion.
JohnPinnacle
Hello,
Here are the known's of a chassis:
Inlet open area = 17 inches^2
Outlet open area = 30 inches^2
Internal Fans = 270 cfm (3 fans @ 90 cfm each)
What is the CFM through the system and what's the equations used to figure this out?
I assume that if we had a very small inlet or outlet open area the pressure will build and decrease the CFM. I want to know if my fans will be choked or if they will run at 270cfm.
Thanks a ton!
John
There's just no way to answer your question with any certainty given the small amoutn of information you've provided. Personally I don't think it would be particularly difficult to flow 270 cfm through 17 in^2, but it depends on a lot more than just area.
13K
