| New Reply |
Annihilator method of undetermined coefficients. |
Share Thread | Thread Tools |
| Jul27-12, 12:26 PM | #1 |
I found everything except step #5. Please tell me if I am correct Find a particular solution to (D - 1)(D[itex]^{2}[/itex] + 4D - 12)y = cos(t) using the annihilator approach of the method of undetermined coefficients. 2. Relevant equations 1) Find annihilator 2) Find A = fundamental set of corresponding homogeneous equation 3) Find B= fundamental set of the annihilated equation. 4) B-A = y[itex]_{p}[/itex] 5) Plug in y[itex]_{p}[/itex] to find the coefficients. 3. The attempt at a solution I am going to skip typing my work for Steps 1-4, because it would take an insane amount of time. 1) D[itex]^{2}[/itex]+1 annihilates cos(t) 2) Set A = [e[itex]^{t}[/itex], e[itex]^{-6t}[/itex], e[itex]^{2t}[/itex]] 3) Set B = [e[itex]^{t}[/itex], e[itex]^{-6t}[/itex], e[itex]^{2t}[/itex], cos(t), sin(t)] 4) B-A = [cos(t), sin(t)] So y[itex]_{p}[/itex] = c[itex]_{1}[/itex]cos(t) + c[itex]_{2}[/itex]sin(t) 5) Expanded equation: (D[itex]^{3}[/itex]+3D[itex]^{2}[/itex]-16D+12)(c[itex]_{1}[/itex]cos(t) + c[itex]_{2}[/itex]sin(t)) = cos(t) After fully expanding using FOIL, 9c[itex]_{1}[/itex] - 17 c[itex]_{2}[/itex] = 1 17c[itex]_{1}[/itex] + 9c[itex]_{2}[/itex] = 0 I used matrix transformations to find c[itex]_{1}[/itex] = [itex]9/370[/itex] and c[itex]_{2}[/itex] = [itex]-17/370[/itex] Am I correct? These solutions seem way too messy compared to what he has given us in the past. In class, he solved Step 5 without actually FOILing the equation, which I did not quite follow, but if I could figure it out it would be much easier than spending several minutes doing monotonous algebra. I know for a fact he will give us an equation like this (with cos(t) and sin(t)) on the final exam because he did the same for the normal test. |
| Jul27-12, 02:01 PM | #2 |
The way to check if it is correct is to plug the answer back into the equation and see if it works. To save you some time, I let Maple do the grunt work and your answer for ##y_p## is correct. Good work.
| New Reply |
| Thread Tools | |
Similar Threads for: Annihilator method of undetermined coefficients.
| Method of Undetermined Coefficients | Differential Equations | 2 | ||
| Method of Undetermined Coefficients | Calculus & Beyond Homework | 3 | ||
| How to use of the method of undetermined coefficients | Differential Equations | 2 | ||
| ODE - Comining Undetermined Coefficients Method with Variation of Parameters Method | Calculus & Beyond Homework | 2 | ||
| Method of Undetermined Coefficients | Calculus & Beyond Homework | 1 | ||
