| New Reply |
Center of mass of infinite cylinder of air |
Share Thread | Thread Tools |
| Jul29-12, 12:15 AM | #1 |
The density of air at height z above the Earth’s surface is proportional to e^(−az) , where a is a constant > 0. Find the centre of mass of an infinite cylinder of air above a small flat area on the Earth’s surface. Hint : Consider line density and the identities: [itex]\frac{d}{dz}e^{-az}=-ae^{-az}[/itex] [itex]\frac{d}{dz}((az+1)e^{-az})=-a^{2}ze^{-az}[/itex] 2. Relevant equations Center of mass = [itex]\frac{1}{M}\sum{m_{i}x_{i}}=\frac{1}{M}\int{xdm}[/itex] 3. The attempt at a solution I have no idea how to get started because I don't know how to use the e^(-az) expression. Could I just write that the density of air at height z = be^(-az) where b is some constant of proportionality? Then I think I would try to find M and dm/dx, plug it into the center of mass equation and integrate from 0 to infinity? |
| Jul29-12, 04:47 AM | #2 |
Recognitions:
ehild |
| Jul29-12, 11:32 PM | #3 |
Thanks :) I did the calculation and got 1/a, is that correct?
| Jul30-12, 12:49 AM | #4 |
Recognitions:
Center of mass of infinite cylinder of airehild |
| Jul30-12, 12:56 AM | #5 |
Thanks again!
| New Reply |
| Thread Tools | |
Similar Threads for: Center of mass of infinite cylinder of air
| An items reaction to a gravitational pull inside a hollow cylinder of infinite mass? | General Physics | 5 | ||
| Acceleration of Cylinder's Center of Mass (Due 9AM) | Introductory Physics Homework | 1 | ||
| center of mass of semicirculardisk calculated from center of mass of semicircular arc | Introductory Physics Homework | 5 | ||
| Center of mass for a cylinder with water | Introductory Physics Homework | 19 | ||
| [SOLVED] Center of Mass of compound cylinder | Introductory Physics Homework | 13 | ||
