| New Reply |
Conservation of Angular Momentum Experiment: Moment of Inertia |
Share Thread | Thread Tools |
| Jul29-12, 09:31 PM | #1 |
I did a lab where there was a rotating solid disk with mass= 0.915kg and diameter=0.253m. This was rotating horizontally with an initial angular velocity of 3 different values ω radians/second. After recording the initial angular velocity, I dropped a thin-walled hollow cylinder with mass=0.708kg and diameter=0.125m in the center and measured the final angular velocity, testing the conservation of angular momentum. Issue: If I placed the ring off center of the disk by say, 1cm (0.01m), how will that affect my moment of inertia? 2. Relevant equations Idisk=(1/2)(Mass)(radius)2 Ihoop/hollow cylinder=(Mass)(radius)2 Li=Idiskωdisk initial Lf=(Idisk+Ihoop/hollow cylinder)ωcombined final 3. The attempt at a solution First, I calculated the moments of inertia- Idisk=(1/2)(Mass)(radius)2=(1/2)(0.915kg)(0.253m/2)2=0.00732kgm2 Ihoop/hollow cylinder=(Mass)(radius)2=(0.708kg)(0.125m/2)2=0.00277kgm2 Icombined=(0.00732kgm2)+(0.00277kgm2)=0.01009kgm2 The Icombined is for the ideal situation of the ring being completely centered, but I have no idea what I would do to get the experimentally flawed moment of inertia. Would I just change the radius of the hoop/cylinder by 1cm? If so, would I add or subtract? I'm really not sure how I'd calculate it. I understand this all generally pretty well, but executing this has me a little stumped. I need a way to get the new final moment of inertia instead of the ideal (Idisk+Ihoop/hollow cylinder) to calculate a percent error. |
| Jul29-12, 10:16 PM | #2 |
Hi, chrismoon. Have you studied the "parallel axis theorem"? You can use it to calculate the moment of inertia of the hollow cylinder when it is placed off-center on the disk.
| Jul29-12, 10:17 PM | #3 |
have you used the parallel axis theorem?
ok then... late again, sorry. Its getting strange how I am right behind Tnsy. I will now bow out again. |
| New Reply |
| Thread Tools | |
Similar Threads for: Conservation of Angular Momentum Experiment: Moment of Inertia
| Angular momentum of rigid bodies,When to add (moment of inertia*angular velociy) | Introductory Physics Homework | 0 | ||
| Moment of Inertia and Angular Momentum | Introductory Physics Homework | 5 | ||
| Physics Rotating Disk, Moment of Inertia, Angular Momentum, Angular Velocity | Introductory Physics Homework | 12 | ||
| Angular momentum, moment of inertia etc. | Introductory Physics Homework | 9 | ||
| HELP:moment of inertia/angular momentum | Introductory Physics Homework | 2 | ||
