Can You Solve This Aerodynamic Drag Problem for Our Paper Airplane Contest?
  • Context: Undergrad
  • Thread starter Thread starter noble24
    Drag
The discussion revolves around solving an aerodynamic drag problem related to a paper airplane contest. Participants are exploring the mathematical modeling of velocity changes over time due to drag forces, including the effects of various parameters such as mass, wing-span, and launch angle.
  • One participant presents a difference equation for velocity that incorporates drag and seeks a continuous function for velocity over time.
  • Another participant suggests that if the drag coefficient is constant, the difference equation can be transformed into a differential equation, leading to a specific solution for velocity.
  • A participant expresses confusion over the transition from the difference equation to the proposed solution and requests intermediate steps for clarity.
  • There is a discussion about the impact of adding a constant term to the equation, which alters the solution significantly.
  • One participant claims that their derived equation involving the tangent function does not yield realistic results compared to the earlier solution, raising concerns about the validity of their approach.
  • Another participant questions the modification of the original equation, suggesting that it had previously produced satisfactory results.
Participants do not reach consensus on the correct approach to the problem. There are competing views regarding the validity of different equations and their respective solutions, with some participants defending their methods while others challenge them.
There are unresolved mathematical steps and assumptions regarding the constants involved in the equations. The discussion reflects varying interpretations of the impact of modifications to the original equation.
noble24
I need some help. Our company is holding a paper airplane constest for distance and I've been trying to work out the math to find the best mass, wing-span, wing-chord, launch angle, etc. combination. I've worked through a bunch of the math but I've just been stumped by what appears to be a pretty simple problem. In essense, the current speed equals the previous speed minus the drag:
[itex]V_{t+\Delta t}[/itex] is the velocity at the current time,
[itex]V_{t}[/itex] was the velocity at the previous time,
[itex]\mu[/itex] is a mindless coefficient (includes mass, surface area, etc.),
[itex]\Delta t[/itex] is the difference in time between [itex]V_{i}[/itex] and [itex]V_{i+1}[/itex].
[itex]V_{t+\Delta t} = V_{t} - \mu (V_{t}^2) \Delta t[/itex]
So, given the initial speed, at [itex]t = 0[/itex] will be, let's say, 20m/s, I want a continuous function that will tell me the velocity as a function of time. I know there is a slope-integration-trapezoidish thing that will solve this in a heart beat, but I just can't seem to think of it.
If [itex]\mu[/itex] is a constant then you can turn your difference equation into a differential equation in the limit of small [itex]\Delta t[/itex] and you should have no difficulty demonstrating that
[tex]V = \frac {V_0}{1 + \mu V_0 t}[/tex]
is the required solution.
Alright. I've had quite the difficulty figuring out how you got from my difference equation to the solution. I've hunted through my math books and through numerous sources on the internet. I really want to know how to do this, so a couple of intermediate steps would be nice to see. I've found my equation to be incorrect as well. The equation is:
[itex] V_{t+ \Delta t} = V_{t} - \mu(V_{t}^2) \Delta t - \beta \Delta t[/itex]
where mu and beta are constants.
Wht do you know about calculus,then...?U know that you can approximate
[tex]V_{t+\Delta t}-V_{t}[/tex]
with the differential of V(t) and
[tex]\Delta t [/itex]<br /> <br /> with the differential of 't'.Then u'd have to separate variables & integrate...<br /> <br /> Daniel.[/tex]
is the solution to the previous problem [Thanks Tide!] and I want a to know how to do it. I can't get figure out how to get this solution by separating and integrating. When I do that, I get:
[itex] V = \frac {tan( t \sqrt \mu \sqrt \beta) * \sqrt \mu} {\sqrt \beta} + C[/itex]
Which is WAY different than the above solution. If you can do it, dextercioby, I'd love to see it so I can understand how to do these problems. But if you can't or aren't willing to walk through some of the steps to actually help me understand, I'd appreciate it if you just let someone else answer the question. Thanks.
It is,because it's ANOTHER EQUATION.As u may have noticed (i DID),adding a constant term changes the solution dramatically.
So yes,your solution containing "tangent" of time is correct,but only for the modified (second posted) equation...
Daniel.
Problem is, the tan() equation is wrong. It does not produce realistic results. With an initial speed of 20m/s, and t = 2 the equation produces a velocity of 19.84m/s. Which is not possible. The actual velocity should be closer to 5.7m/s as predicted by the previous solution. There is a problem somewhere, and I'm betting on the approach.
Then it must be another equation to begin with.I don't know why you've changed the first,as it had yielded good results...
Daniel.
