Strange question with 2 charges, and net electric field between them = 0
The discussion revolves around a problem involving two fixed point charges, -16 mC and +4.0 mC, separated by a distance of 3.0 m. Participants are tasked with finding the location along the line connecting the charges where the net electric field is zero, as well as determining the force on another charge placed at that location.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the formula for the electric field due to a point charge and its directional properties. There are attempts to set the electric fields from both charges equal to each other to find the point where the net electric field is zero. Some participants express confusion about isolating variables in their equations and question the setup of the problem.
The discussion is ongoing, with participants exploring different interpretations of the problem setup and the mathematical relationships involved. Some guidance has been offered regarding the electric field's direction and the setup of equations, but there is no explicit consensus on the next steps or solutions.
Participants note potential confusion regarding the units of the charges (mC vs. μC) and the implications this may have on their calculations. There is also mention of the lack of provided formulas from the instructor, which adds to the complexity of the problem for the original poster.
michaelw
Two charges, –16 and +4.0 mC, are fixed in place and separated by 3.0 m. (a) At what spot along a line through the charges is the net electric field zero? Locate this spot relative to the positive charge. (b) What would be the force on a charge of +14 mC placed at this spot?
I am totally flabbergasted by this question
Our prof doesn't really give many formulas, or any at all, as we generally have to figure out what to use and when
But in this case, what formula would you use to even get started?
For A, what is the equation for and electric field E due to a point charge q at a distance r from the charge? What is the direction of the field?
That's all you need, plus some algebra.
For B, no formula at all, just some thought.
the E set up by a point charge q at a distance of r is
[tex]\vec{E} = \frac{kq}{r^2}[/tex]
the [itex]\vec{E}[/itex] points away from q if q is positive, and towards q if q is negative
wow I am confused
and this is simple too..
charge 1 points to the 'left' (assume left is where the -16mC charge is)
charge 2 points to right
so you set
E1 = E2
but how do you isolate r^2 now? you end up with
value/r^2 = value/r^2..
if you multiply both sides by r^2, they cancel.. clearly I am missing something elementary
vaxopy said:
wow I am confused
what do you mean charge 1 points to the left? The electric field set up by a negative point charge points toward the charge, but this is relative to where your evaluating the electric field from. Conversely, the electric field set up by a positive point charge points radially away from the charge
so you set
E1 = E2
First try to figure out where the the point must be located relative to the two point charges.
-------------(-16mC)---------------(+4mC)---------------->x
[tex].\ \ \ \ \ \ \ \ \ \ a \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ . \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ b \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ c[/tex]
as you see the digram sets up three intervals as to where the point might be where the E = 0.
edit: the letters above just indicate the three separate intervals, and do not represent length
MathStudent said:
what do you mean charge 1 points to the left? The electric field set up by a negative point charge points toward the charge, but this is relative to where your evaluating the electric field from. Conversely, the electric set up by a positive point charge points raidally away from the charge
--------------(-16mC)---------------(+4mC)------------------>x
[tex].\ \ \ \ \ \ \ \ \ \ 1 \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ 2 \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ \ 3[/tex]
heres what i did..
(8.99*10^9)(4*10^-6)/m^2 = (8.99*10^9)(16*10^-6)/(m+3)^2
m is the distance between 4uC and x
i then got
((3+m)^2)/(m^2) = 4*10^-6
am i on the right track? how can i solve for m now? (i don't have a graphing calculator)
michaelw said:
heres what i did..
Equation looks good!
I just want to mention something about the charges though. Just so you know mC represents millicoulombs (10^-3 C), and [itex]\mu C[/itex] represents microcoulombs (10^-6 C). Did the question give the charges in mC or [itex]\mu C[/itex]? If its supposed to be millicoulombs, then your charges are wrong.
i then got
LHS looks good, but what is (16*10^-6 / 4*10^-6), its not 4*10^-6.
You don't need a graphing calculator to solve this, just a little algebra.
  • · Replies 68 ·
9K
  • · Replies 26 ·
