Need help with tension in a string/charged balls attached
  • Thread starter Thread starter vaxopy
    Balls Tension
The discussion focuses on calculating the charge on two identical small insulating balls, each with a mass of 8.0×10-4 kg, suspended by 0.25-m threads, which form an angle of 36° when charged positively. To determine the charge on each ball and the tension in the threads, one must analyze the forces acting on the balls using free body diagrams. The scenario can be modeled as an isosceles triangle due to the equal length of the threads and identical mass and charge of the balls.
  • Understanding of free body diagrams
  • Knowledge of electrostatic forces
  • Familiarity with tension in strings
  • Basic principles of trigonometry
  • Learn how to create and interpret free body diagrams in physics
  • Study Coulomb's Law for calculating electrostatic forces
  • Explore the concept of tension in strings and its applications
  • Review trigonometric functions and their use in solving physics problems
Students studying physics, particularly those focusing on mechanics and electrostatics, as well as educators looking for practical examples of tension and charge interactions.
vaxopy
Two identical small insulating balls are suspended by separate 0.25-m threads that are attached to a common point on the ceiling. Each ball has a mass of 8.0×10–4 kg. Initially the balls are uncharged and hang straight down. They are then given identical positive charges and, as a result, spread apart with an angle of 36° between the threads. Determine (a) the charge on each ball and (b) the tension in the threads.
Its been a long time since I have worked with tension.. and free body diagrams. Can someone please provide a kick for me in the right directoin? What would the diagram look like (free body/forces), and how would I go about solving this?
Given that the threads are equal length, attached to the same point at the top, and the masses and charges of the balls are equal, it would look like an isosceles triangle, and you know, or can figure out, all the dimensions. And you should be able to determine what forces apply and in what directions. What's holding you back?
  • · Replies 16 ·
10K
