How Is the Operator d/dx Conceptualized in Calculus?
  • Context: Undergrad
  • Thread starter Thread starter FlyingPanda
The discussion centers around the conceptualization of the differential operator d/dx in calculus, exploring its nature as an operator, its application in expressions, and the implications of treating it algebraically. Participants engage with both theoretical and practical aspects of this operator, including its relationship to linear operators and the challenges of understanding its manipulation in equations.
  • One participant expresses discomfort with the treatment of d as a constant in algebraic expressions, questioning how it can be manipulated similarly to regular numbers or functions.
  • Another participant defines d/dx as an operator that takes a function as input and returns its derivative with respect to x.
  • A participant challenges the idea of adding the operator d/dx to 1, questioning how an operator can be assigned a numerical value in an equation.
  • One response introduces the concept of linear operators, suggesting that understanding this framework may clarify the operation of differential operators.
  • Another participant corrects a misunderstanding regarding the application of the operator, emphasizing that d/dx + 1 should be viewed as an application to a function rather than a simple arithmetic operation.
Participants do not reach a consensus on the manipulation of the differential operator d/dx. There are competing views on how to conceptualize and apply this operator, with some participants expressing confusion and others providing clarifications.
Limitations include the potential misunderstanding of operator algebra and the distinction between applying operators and performing arithmetic operations. The discussion reflects varying levels of familiarity with linear operators and their implications in calculus.
FlyingPanda
Hi all,
I was relatively comfortable with Leibniz's notation of dy, dx as representing infinitesimally small values of change in y and x, however I was watching a Math lecture yesterday where I saw something I was simply unable to conceptualise.
I've always seen the d as an operator, that functions in the same way as the sine, cosine, tan, log, etc functions. d(x) is taking the input x and performing the differential operation on it, outputting .dx -> which is the infinitesimally small change in the variable x. This by itself is meaningless, unless it is put in a statement with another infinitesimal, such as dy, whereby ratios give meaning to the expression.
However, I saw the use of the annihilation operator in the following expression:
(d/dx + x) y = dy/dx + xy
I know algebraically it works, but it treats d as if it is some simple constant. Seeing d/dx by itself was too difficult to conceptualise, I can't grasp the meaning of it. For me it was akin to seeing:
(sin( /sin(x) + x)y = sin(y)/sin(x) + xy.
So, my questions are:
1. Can you simply pull the input of a differential away from the expression
-> dx + x = (d + 1)x
2. How do you conceptualise what the meaning of d/dx is. What does it actually mean?
Thanks for your help!
An operator whose input is a function and returns the derivative of that function with respect to the variable x.
But how can an operator be added to 1, and then multiplied.
Let's take this case,
d(x^2)/dx + x^2 = 35
(in this case, x is 5)
(d/dx + 1)x^2 = 35
d/dx + 1 = 35/x^2
d/dx + 1 = 7/5
d/dx = 2/5
How can d/dx just simply be "given" a value?
Hey FlyingPanda and welcome to the forums.
Are you familiar with a linear operator? Do you know what a matrix is?
The reason is that a differential operator is a linear operator, and understanding this can help in understand how this operator works. When you extend this idea to how you take say a function of a linear operator (as is done in operator algebra's and extended frameworks of linear algebra), this concept is solidified.
In fact if you ever see operator methods for solving DE's, you'll see that when you get things like 1/(D+4)f(x), you expand out the terms by doing what you do with polynomials which is long-division. This would seem un-reasonable, but when you look at the theory of how to calculate (functions of linear operators), then this will be easier to understand.
The short answer is that it's not easy if you try and think about it symbolically, but it becomes easier if you think about the differential operator being linear (think of the tangent nature of a derivative and what the derivative is: a slope or a linear rate of change at a particular point) and then if you want to get rigorous, you look at the theory of linear operators, which is something that John Von Neumann looked at.
Because "1", in this case, is also an operator. It is the identity operator that takes every x to itself.
(d/dx + 1)x^2 = 35
d/dx + 1 = 35/x^2
This last step is incorrect. You are NOT multiplying "d/dx+ 1" by x^2, you are applying the operator d/dx+ 1 to x^2. The error is exactly the same as if you were to say "sin x= 1 therefore sin= 1/x".
d/dx + 1 = 7/5
d/dx = 2/5
It can't. Your error is as I pointed out.
