Calculating Flow Rate and Fill Time for Gravity-Fed Water Trucks
  • Thread starter Thread starter beachfarmer
    Gravity Water
The discussion revolves around calculating the flow rate and fill time for two 5,000 gallon water trucks being filled from a 20,000 gallon circular water storage tank using gravity. The focus includes the application of Bernoulli's Equation and considerations of pipe flow dynamics, including the effects of elevation and pressure changes during the filling process.
  • Homework-related
  • One participant seeks assistance with applying Bernoulli's Equation to determine the flow rate at the spigot and the time required to fill the trucks.
  • Another participant suggests using software for calculations but does not provide a direct solution.
  • There is a discussion about the dimensions of the water truck tanks, with one participant questioning their impact on flow rate, while another compares it to a waterfall scenario.
  • A participant discusses the pressure dynamics at the spigot as the water level in the truck tanks rises, indicating that the pressure will increase and affect the outflow from the storage tank.
  • Clarifications are made regarding the height of the spigot relative to the truck tanks and the implications for flow rate.
  • One participant expresses uncertainty about the interpretation of the problem, suggesting that the filling process may involve complexities beyond straightforward physics.
Participants express varying levels of understanding and uncertainty regarding the problem. There is no consensus on the significance of the truck tank dimensions or the implications of pressure changes during filling.
Some assumptions about the system, such as the dimensions of the truck tanks and the effects of pressure buildup, remain unresolved. The discussion reflects differing interpretations of the problem's parameters.
beachfarmer
Greetings:
I'm a bit rusty on Bernouli's Equation...any help is appreciated.
I would like to fill two 5,000 gallon water trucks from a 20,000 gallon circular water storage tank by gravity. Here is the info:
1. The 20,000 gallon storage tank is a cylinder and sits vertical. It is approximately 15 feet in diameter and 15 feet tall. The exit orfice is at the center on the bottom of the tank.
2. There is 100 feet of 12 inch PVC piping from the tank to a tee that reduces each branch to 6 inches. There is an additional 10 feet of 6 inch piping off each branch which are terminated with a spigot. At each spigot the truck hose is connected, and when opened, fills the water tanker trucks.
3. Assume two 90 degree elbows in the12 inch PVC and another 90 degree elbow in each 6 inch branch.
4. Assume 5 feet of head between the storage tank orfice and the spigot and that the orfice elevation is equal to the top of the water truck tank.
Questions:
1. What is the flow rate at the spigot?
2. How long does it take to fill the 2 trucks simultaneously?
Bernoulli and pipe flow
Need your help!..any info is appreciated
I've no idea how to approach your problem but this software looks like it can do it and here is a free trial version..
http://www.pipeflow.com/
I've no connection with the company that produced it.
beachfarmer said:
Greetings:
Questions:
Before I look at this I would want the dimensions of the water truck tanks. It might make a difference whether those tanks are narrow and deep or wide and shallow. If you weren't given those dimensions in a problem set then maybe it doesn't, but I would like to know.
I'm curious why that would make a difference?
The size of the pond at the bottom of a waterfall has no effect on the flow rate of the waterfall.
Like I said, I'm not sure.
Per your description, if I got it right, the spigot is 5' below the top of the truck tanks. At first the truck tanks are empty and the pressure p at the spigot is 1 at. But once the water level inside the truck tanks reaches the spigot level, p increases beyond 1 at. to ρgh where h is the height of the water column above the spigot. Which of course is building up continuously. For h > 0 the ensuing pressure buildup at the spigot will slow down the rate of storage tank outflow to accommodate Bernoulli, viz. p + ρgh + ρv2/2 is conserved, and p will be building up inside the truck tanks once the spigot level is reached.
Make any sense?
Minor edit.
Ah ok I understand. I didn't spot that bit.
It seems as much an exercise in comprehension (i.e., mind reading) as physics. My interpretation:
The (sic) truck hose sounds singular, so most likely is the discharge hose from the base of the tanker, so it follows when filling via this route there is always water pressure to overcome.
You are filling (sic) the tankers, so the water in the tank being filled rises to the same level as the storage tank orifice. Might it be necessary to assume the truck tanks are 5m in height? Or maybe it doesn't matter?
10K
  • · Replies 17 ·
