Speed of atoms ejected from an oven
by Jolb
Tags: atoms, ejected, oven, speed
Jolb
Jolb is offline
#1
Aug1-12, 06:59 PM
P: 419
My question is this: what is the average speed of atoms released from an oven at some temperature T? For example, in a Stern-Gerlach experiment, hydrogen atoms are emitted from an oven and collimated into a beam by passing them through a slit (and then sent into an inhomogenous magnetic field, but I don't really care about these details for this particular question).
The reason I am confused about this is because my gut instinct would be to estimate this using the old thermodynamic expression for an ideal gas: E = 3/2 kT = 1/2 mv^2 which would imply [tex]v=\sqrt{\frac{3kT}{m}}[/tex]
However, upon cracking open my thermodynamics textbook, it seems as though this is the RMS speed of atoms in a gas, rather than the boring-old average speed. The boring old average speed is found by calculating the expectation value of speed in the Maxwell-Boltzmann distribution, as such:
[tex]\langle v \rangle = \int_0^{\infty} v \, f(v) \, dv= \sqrt { \frac{8kT}{\pi m}} [/tex]
They are very close: the factor of 3 just changes to 8/∏. But which one should I use in a Stern-Gerlach question? Which one would actually be observed in a collimated beam of atoms emitted from an oven at temperature T?
Edit: Just to clarify, even though I am using the symbol v, which is usually reserved for the velocity, here I am referring to the speed, which is equal to the magnitude of the velocity vector. That is to say, v=|v|.
Phys.Org News Partner Physics news on Phys.org
Physicists design quantum switches which can be activated by single photons
'Dressed' laser aimed at clouds may be key to inducing rain, lightning
Higher-order nonlinear optical processes observed using the SACLA X-ray free-electron laser
Simon Bridge
Simon Bridge is online now
#2
Aug2-12, 02:11 AM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
Simon Bridge's Avatar
P: 10,993
The second one.
Jolb
Jolb is offline
#3
Aug2-12, 10:35 AM
P: 419
The second one does seem more obvious, but why does my "gut instinct" derivation fail? It seems to me that if we know some expression for the average kinetic energy (E=3/2 kT), the expression should give the average speed, not the RMS speed. Why does that derivation give RMS rather than the correct answer?
Also, references would be appreciated.
Simon Bridge
#4
Aug4-12, 10:33 PM
Homework
Sci Advisor
HW Helper
Thanks ∞
PF Gold
P: 10,993
Depends what you are deriving and how you go about it.
The rms velocity is what you get in the first one because the particles in the gas are equally likely to be heading an any direction - giving an average velocity of zero. You can see why this is not useful.
Put a hole in the walls though, and you are selecting for those particles that are headed in a subset of possible directions.
Register to reply
Related Discussions
What comes out of an 'atomic oven' - atoms, ions? Atomic, Solid State, Comp. Physics 2
On "Microwave oven to measure light of speed". To falsify Classical Physics 0
Using a Microwave Oven to Measure the Speed of Light Introductory Physics Homework 4
What is the maximum speed of the ejected electrons? good times! Introductory Physics Homework 5
Speed of electrons ejected Introductory Physics Homework 1
