Logarithms/intro to logarithms (how did they the get solution?)
  • Thread starter Thread starter supernova1203
    Logarithms
The discussion revolves around understanding logarithms, particularly how the solution of 7/2 is derived in relation to logarithmic properties and exponents. The original poster expresses confusion about the application of logarithms and square roots in this context.
  • The original poster seeks clarity on how the exponent of 1/2 is applied to the square root and how this leads to the solution of 7/2. They request a detailed explanation of the thought process involved in solving such problems.
Some participants have provided insights into the properties of exponents and logarithms, suggesting that understanding these properties is crucial for grasping the solution. However, the original poster's request for a step-by-step explanation indicates that further clarification may still be needed.
There is a mention of confusion regarding notation and the properties of exponents, particularly in relation to square roots. The original poster's uncertainty about logarithmic concepts suggests a foundational gap that may affect their understanding of the problem.
supernova1203
I have no idea how they came up with 7/2 as a solution...can anyone tell me how? I am not sure how logarithms and square roots work...how did they get the 1/2 exponent over the second 2? What is the train of thought required to solve a question like this??... for example
you do this...then you do that...and using that you get 7/2...can someone explain to me? in detail how they got 7/2?
Your links don't work.
Try again...i re did them...and they seem to work now.
Looks like magic!
Do you know the "properties of exponents"? [itex]a^xa^y= a^{x+y}[/itex] and [itex](a^x)^y= a^{xy}[/itex]
The logarithm is the opposite of the exponential: [itex]log_a(a^x)= x[/itex] and [itex]a^{log_a(x)}= x[/itex] (the technical term is "inverse") so logarithms have the opposite properties: [itex]log_a(xy)= log_a(x)+ log_a(y)[/itex] and [itex]log_a(x^y)= y log_a(x)[/itex]
So, for example, [itex]log_3(27\sqrt{3})= log_3(3^3(3^{1/2})= log_3(3^{3+ 1/2})= log_3(3^{7/2})= 7/2[/itex]
That, as well as, [itex]log_2(8\sqrt{2})= log_2(2^3(2^{1/2})= log_2(2^{3+ 1/2})= log_2(2^{7/2})= 7/2[/itex]
are both applications of [itex]log_a(a^x)= x[/itex]. The "logarithm" and "exponential" are inverse functions so they "cancel".
A notation that is used for square roots is to raise the number to the one-half power.
So the square root of two is equivalent to ##2^{\frac{1}{2}}##.
On a similar note, the cube root of two is equivalent to ##2^{\frac{1}{3}}##. (this isn't relevant for this problem, but I feel like it helps you understand the rule a little better.
  • · Replies 22 ·
