| New Reply |
Method of Pins- Trusses (conceptual) |
Share Thread |
| Aug2-12, 07:49 PM | #1 |
I am designing a bridge that looks like this: http://imgur.com/zFsW7 and using the method of joints to find the tension in each pin. The bridge has to hold 10,000 lbs on each pin, and we have to find the maximum tension in each member (so tension of each member when the weight is on A, then 10,000 B, etc.) I'm checking my answer by placing the 10,000 lbs on pin I and checking symmetry. (I can't really show work because its in an excel spreadsheet and there are quite a few joints). Every answer is tension is symmetrical except GH/HK and FH/HJ. Attempt at problem So, based on summations in the x direction for the pins G and K, GH=DG and HK=KL. So the entire top truss should have equivalent tensions (besides CA and OP)? I don't understand how that works. Will GH=HK no matter where the weight is placed on the bridge? |
| Aug2-12, 08:19 PM | #2 |
Recognitions:
Did you have a "negative Tension" value - indicating it is actually compression in that member? |
| Aug2-12, 09:33 PM | #3 |
Yeah, GH, HK, DG, and KL are all compressive
| New Reply |
Similar discussions for: Method of Pins- Trusses (conceptual)
| Pins for Low Temperature PCB | General Engineering | 0 | ||
| Adding the currents of all pins | Electrical Engineering | 3 | ||
| Trusses- Analytical Method. | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Me poor old pins | General Discussion | 29 | ||
| Hanging pins | Electrical Engineering | 10 | ||
