| New Reply |
What is work? |
Share Thread |
| Aug4-12, 07:48 AM | #1 |
What is work?
Okay i know that energy is the ability or capacity to do work. But how do you define work, as like the isnt work just the transference of energy in one form to another? Which is kinda circular reasoning. Like the rely on each other for a defintion. Is that right?
| Aug4-12, 07:53 AM | #2 |
Mentor
The appropriate definition of work depends on what theory you are using.
One is the mechanical definition: "work is f.d". This definition is used in basic Newtonian mechanics. In it forces are the primary things and everything else is defined based on forces. Then energy is non-circularly defined as the capacity to do work. The other is the thermodynamic definition: "work is a transfer of energy other than through heat". This definition is used in Lagrangian and Hamiltonian mechanics as well as all field theories. In these, the Lagrangian is the primary thing and everything else is defined based on the Lagrangian. Then energy is non-circularly defined as the conserved quantity associated with time invariance of the Lagrangian. |
| Aug4-12, 07:55 AM | #3 |
Mentor
http://hyperphysics.phy-astr.gsu.edu/hbase/wcon.html Zz. |
| Aug4-12, 08:03 AM | #4 |
What is work? |
| Aug4-12, 08:11 AM | #5 |
Mentor
The basic distinction is that heat is a rather disorganized microscopic transfer that you cannot see in detail, as opposed to things like macroscopic fields and forces. |
| Aug4-12, 08:17 AM | #6 |
| New Reply |
Similar discussions for: What is work?
| Is there a difference between how pem fuel cells work and typical batteries work? | Biology, Chemistry & Other Homework | 0 | ||
| Finding velocity and work involving friction Work Energy | Introductory Physics Homework | 9 | ||
| The conservation of energy, why does it work? Negative work vs positive work | Introductory Physics Homework | 54 | ||
| Partial fractions QUICK question, zero work required, just knowledge of how they work | Calculus & Beyond Homework | 2 | ||
| Work to push a sled up a hill: Friction, inclines,force,work | Introductory Physics Homework | 2 | ||
