What cosmological event could snuff out the sun without destroying Earth?
The discussion revolves around hypothetical cosmological events that could lead to the sun ceasing to provide energy to Earth, resulting in a potential end to life on the planet. Participants explore various scenarios, including the effects of massive celestial objects and advanced technologies, while considering the implications for human survival and preparation.
  • One participant suggests a scenario where an approaching massive object, such as a planet-sized rock or black hole, could alter Earth's orbit, leading to reduced sunlight.
  • Another participant proposes that a passing star could modify planetary orbits significantly, potentially ejecting Earth from the solar system.
  • A direct collision with a black hole is mentioned as a possibility, though it is noted that this would likely destroy the sun.
  • Some participants discuss the long-term fate of the sun, predicting it will eventually become a red giant, which could engulf Earth.
  • One participant raises the idea of using advanced technology, either human-made or alien, to move Earth instead of altering the sun.
  • Another suggests that darkening Earth's sky through a global catastrophe could mimic the effects of losing sunlight without directly affecting the sun itself.
  • Concerns are raised about the detectability of black holes and their potential effects on Earth, including tidal forces if they come too close.
  • Participants discuss the feasibility of detecting a black hole's gravitational influence and the implications for predicting its trajectory.
Participants express a variety of competing views on the likelihood and mechanisms of different cosmological events that could affect the sun and Earth. There is no consensus on which scenario is most plausible or how likely such events are to occur.
Some participants note limitations in current understanding of black hole dynamics and the challenges of detecting such objects in space. The discussion includes assumptions about the behavior of celestial bodies and the technological capabilities required for potential solutions.
Writers and creators interested in science fiction scenarios involving cosmological events, as well as those exploring the implications of celestial mechanics on planetary survival.
CCWilson
I'm considering writing a story in which we Earthlings have a few years to prepare for a cosmological catastrophe in which our planet will lose its energy source and be adrift in space. This would mean the end of life on Earth - but not right away. We could insulate giant underground chambers and tap existing energy sources in order to perpetuate human life for a number of generations into the future. Fun and complications would ensue.
So my first problem is figuring out how to create such a disaster in a believable way. I assume that long before our sun dies, it would go through a contraction phase to become a red dwarf or something and fry us for dinner. Do we believe that some stars of the size of the sun are capable of simply becoming dimmer and finally winking out? Didn't think so.
How about a scenario in which we become aware of an approaching mass - a planet-sized rock or black hole or something that we knew would hit our solar system and might somehow knock the Earth into a more distant orbit so that we would no longer receive enough sunshine to sustain life?
I'd appreciate any suggestions from you brainiacs.
- another star, crossing the inner solar system. Its gravity could modify the orbits significantly, or even catapult some planets into the interstellar region. It is possible to predict the motion of all nearby stars at least for (at least) the next hundred thousand years, giving a large time to prepare.
- a black hole, crossing the inner solar system. Similar to above, maybe harder to see in advance.
- a direct collision of a black hole and the sun. Similar to above, but I would expect that the sun will not survive this. Might have some bad side-effects.
- sufficiently advanced technology, earth-based or alien (moving the Earth is way easier than messing around with sun)
- in several billion years, sun will become a red giant, burning everything on the surface and probably swallow earth. If not, the sun gets smaller again, reducing its luminosity. If some life somehow survived this, it will face an eternity of (nearly) darkness.
As you can see, the sun is quite robust. Just one option I found (the direct collision with another object of stellar mass) really modifies the sun in a significant way before it dies.
The end of life for the sun has it becoming a red giant, which might swallow up the earth. To avoid this you need to have the Earth leave the solar system ahead of time (how?).
An object with the mass of the sun could kick us out of the system:
http://tinyurl.com/9e2c6v7
Stop simulation to see the parameters. Than fix the sun and start simulation.
Thanks for your replies. A star couldn't sneak up on us, so that's out for the purposes of the story. So a black hole might be the best candidate, unless an object larger than Jupiter - perhaps a planet from another star system - is possible.
DocStupid, that's a great simulation. Out of curiosity, how did you come to construct it originally? I assume that a black hole the mass of the sun could do what your generic object does in the simulation and sling Earth out into space, as long as it didn't contact us directly.
In the story, scientists would need to become aware of the approaching black hole or whatever several years in advance, so that they would have time to construct a permanent underground city. Since I don't believe that there are any objects that we know about between our solar system and the nearest star, I don't see how the gravitational effects of an approaching black hole would become obvious to us.
One possibility is that a massive black hole is captured in orbit around the sun, so that scientists would become aware of it from its effects on the outer planets, and as the orbit of the black hole slowly spirals inward, scientists would be able to calculate its future effects on the Earth. Perhaps it would be in a big elliptical orbit and we would know at some point it would be destined to cause a slingshot effect as in DrStupid's simulation.
You probably already considered and discarded this, but darkening Earth's sky is a lot easier to accomplish than switching off the Sun, and has similar effects.
In the usual scenarios (nuclear winter, volcanic winter, impact winter), the darkening occurs in the wake of some primary global catastrophe, but it shouldn't be too hard to come up with a scenario that gives you the one without the other, if that's important. For example, there were serious concerns that something rather less dramatic like a sufficiently large number of burning oil wells could have a similar effect (cf wikipedia section on "Kuwait wells in the first Gulf War"). So, make a really big fire somewhere, and it gets really cold everywhere else. And stays that way for as long as the fire burns, and then some.
Of course, the psychological factors are nevertheless quite different in the two situations. Switch off the Sun, and that's it for Earth, all that's left is holding out for as long as possible. Darken the sky, and you know it's going to get better eventually, even though you may not live to see it.
Hmm... objects with a mass comparable to Jupiter might work, too. They have to come very close to Earth (which gives a lot of side-effects like extreme tides), but they are hard to detect.
Black holes could be detected by their gravitational influence, as they would move the apparent position of stars. Gaia should be able to measure the position of many stars with a precision of ~100µas. For a black hole (BH) of 1 solar mass, this corresponds to light passing the BH with a distance of ~2.5*10^10km = 150 AU. Within a year, Gaia will perform several measurements of ~1 billion stars in the full solid angle. Those stars are not distributed evenly in the sky, but I will use this assumption here. Therefore, Gaia can observe a BH if a disk with 150 AU diameter occupies 1/billion of the sky. This gives a radius of ~40 light years. With 100km/s, this corresponds to 120,000 years. Hmm...
Of course, the assumption of a uniform distribution is wrong. Most stars are within the galactic disk, and not close to the sun. But so are most black holes...
Jupiter is lighter by 3 orders of magnitude, reducing all numbers by 3 orders of magnitude. With the same method, we could detect it in a distance of ~2500 AU, giving about 100 years time to prepare. That looks good.
Earth needs a kick of ~20km/s to escape. Using a=GM/r^2, delta_v=a*delta_t, delta_t ~= r/v, v=50km/s, this corresponds to a distance of closest approach of the order of 100,000km - about twice the radius of Jupiter, and comparable to the Roche limit, meaning that Earth would probably break into pieces if the object gets so close. I ignored prefactors here, the distance might be larger by a factor of ~2-3, but tidal forces would be extreme and significantly change the shape of Earth - not a good place to build bunkers.
Not without technology. There are no objects of sufficient mass to capture the black hole.
There is no reason why it should do this.
Thanks, mfb.
Let's say that a black hole with the mass of the sun is approaching our solar system. First of all, how likely is it that there are black holes traveling through space after having been expelled from another star system? If such existed, can we assume anything about its velocity? Is it possible that it would be traveling slowly enough that the gravitational attraction between it and the sun would allow the two to orbit around each other (much like binary stars do)? And if that happened, what would be the effect on Earth even before the proposed slingshot effect?
I had wondered about that possibility. Any idea how accurate scientists could be about the speed and pathway of a sun-sized black hole that approached our solar system? In other words, would they be able to predict not just that it would pass through our solar system, and when, but that it would pass by the Earth in such way as to slingshot it out into space?
I'm not sure about it. This looks like as if it works:
http://tinyurl.com/c9ezmrb
But it is more a collision than a swing by. Earth would be heavily damaged or even destroyed.
In this case the object has ten times the mass of Jupiter:
http://tinyurl.com/corrbmm
As the minimum distance exceeds the Roche limit Earth would at least survive the event.
A solar mass black hole would be unusually small. We have not detected any to date that are much less than about 5 solar masses [an interesting question unto itself]. A brown dwarf, on the other hand, would be much more probable given they are believed to be one of the most common type of star in the galaxy. They are extremely faint, but, typically in the range of 13 to 80 times the mass of jupiter. A body this size would wreak considerable havoc on planetary orbits were it to pass through the inner solar system. Chances are good they would be less than 50 years away, and quite possibly much closer, before detected. Our first clue could well be a sudden increase in the number of comets passing through the inner solar system. It is entirely possible such an event has already occurred in the history of our solar system.
Scientists would know pretty early that a black hole were approaching. As suggested earlier, gravitational lensing would be significant from a measurement standpoint. I believe numerous pulsars are currently used for looking for gravitational waves (search for pulsar timing array). Space telescopes like Kepler rely on precise measurements as well. Both projects would know almost instantaneously that something was wrong, long before we could see what was approaching. *Most experts on those teams would realize fairly quickly that the stars had "moved", and there are very few beneficial reasons for such an event. A black hole would be among the first things considered.
Another effect of an approaching black hole would be a disturbance in the Oort Cloud, the vast region of space beyond Pluto, and extending as much as 3 light years from the Sun, and consisting of trillions of asteroids, comets, and dwarf planet-sized objects like Pluto. The Sun has very little gravitational influence on these objects. They are very loosely bound to the Sun, and any large passing object will throw them off their orbits, either into the solar system or out. A few cosmic impacts with outer planets would be quite interesting from a sci-fi perspective. Of course, a minor impact on Earth or a big one on moon would be fun, too.*
Tidal forces would affect oceans once the black hole start exerting influence on the earth. This could happen 20 years before it got here, allowing for other interesting events.*
A black hole would be almost impossible to capture by our Sun. It would have to be going slow enough already, which is improbable. A close approach and slingshot is more likely. * Also, it would be very hard to fling the Sun out from the solar system without the earth. It would be much more likely for a close call with the Earth flinging the Earth out of orbit instead. Maybe Mars can go with us for *fun. :) Or perhaps the black hole could get so close to the Sun that it sucks away part of the Sun's outer layers? I don't know what effect that would have.*
Perhaps an interesting plot could be that the black hole will miss us, and everything will survive, and everyone rejoices. The black hole missed the keyhole region that it needed to hit. *But then a second black hole is discovered; a binary partner trailing a light year behind. This one will hit the keyhole precisely, and hopes are dashed.*
I look forward to reading this story!
They don't have to be expelled anywhere, all stars have a motion relative to other stars on their own.
A typical velocity is ~20km/s (while some have 200km/s+), gravity would increase this to ~50km/s close to the orbit of earth. As pessimistic values, I used ~100km/s for the approach (very high -> short warning time) and ~50km/s for the close approach (low -> large gravitational influence).
No. In a two-body system, a capture process is impossible. The object cannot be bound gravitationally, otherwise it would have been close to the sun forever.
I am quite sure that the discovery of such a BH will lead to some new telescopes to track it, and telescopes improved so much in the last decades - impossible to tell how good the estimates are in 100 years, yet in 100,000.@Chronos: See my estimate for the gravitational bending of light for black holes, it can be scaled to objects of any mass. Current technology (Gaia, to launch in 2013) can give a warning time of the order of 100years*objectmass/(jupitermass).
In playing with DrStupid's excellent simulation, it's obvious that the pathway through the solar system isn't all that critical in terms of whether it gives Earth a new orbit or an escape velocity. Many combinations will do that. It IS critical as to whether our planet is destroyed or not, which is important, I guess. I did see that the mass of the black hole needs to be close to that of the sun in order to have the desired effect - much smaller and unless it got lucky it wouldn't do a lot, much bigger and we'd soon be within its event horizon.
Chronos, a brown dwarf is an interesting possibility, but would have to hit just right to disturb Earth's orbit, according to the simulation.
If a sun-sized black hole were heading right in our direction, would that make it easier to detect it, or harder?
Thanks, mjacobsca. The Oort cloud sounds like my best shot at detecting the black hole at approximately the right time frame, if I'm to be cosmologically accurate, which I want to be.
Lorenzo Iorio published a paper on this scenario a couple years ago - Is it plausible to expect a close encounter of the Earth with a yet undiscovered astronomical object in the next few years? http://arxiv.org/abs/1009.1374 where he concluded such an event was highly improbable. Obviously, extrapolating this analysis out to 50-100 years significantly increase the probability. Were it traveling at about the same velocity as the sun around the galaxy [~220 km/s], but, in the opposite direction, it would travel about 0.25 AU per day. Assuming its arrival in 50 years, it would currently be around 4500 AU from earth. As a basis for comparison, the aphelion of Haleys comet is about 35 AU.
I am surprised that no one has mentioned hypervelocity stars, which are stars / stellar masses that can have velocities three times that of our Sun's around the galaxy. Here's yet-another awe-inspiring Hubble feat (http://www.popsci.com/technology/ar...mage-speeding-star-expelled-center-our-galaxy), actually detecting one such star which had been part of a trinary orbit until one member was absorbed by the SMBH at the center of our galaxy, transferring the momentum to the other two.
So, one might consider a binary orbit where one member goes supernova and the other gets hurled off on a tangent (as this event could happen far from the center of the galaxy). Still it would take very long for this star to approach the Earth...
Isaac Asimov has a book detailing various ways the Earth might end due to cosmological occurrences. It is highly entertaining to read as it is, and could spark your imagination if not provide an outright answer. https://www.amazon.com/dp/0449900487/?tag=pfamazon01-20
Thanks, H2Bro. I've just placed my order for Asimov's book through Amazon. I think the timing for a star, hypervelocity or otherwise, wouldn't work for my story, though.
If you want to get speculative, let's suppose in 2300 some even genius creates at field that changes the fine structure constant by affecting the Higgs field. He holds the world for ransom, turns off the core of the sun, and then he gets paid, turns off the field and the sun still stays off.
Ooopppsssss...
If the nuclear core of the sun goes off then the sun will still shine for several thousand years.
All right. At this point we have Earth leaving the solar system and underground cities keeping our species alive. What happens to our planet's atmosphere? Do we lose some of it as the black hole passes nearby? Once we are no longer being warmed by the Sun, with all plant and animal life above ground exterminated, do we maintain our atmosphere, or is it slowly lost into space? Could someone in an insulated space suit walk around and get his oxygen, warmed before breathing it, from the air? How chilly would it be?
Incidentally, I'm sure it depends on how close the black hole passes Earth, but should we expect earthquakes and tidal waves before we are slung away from mother Sun?
Very far away from the Sun it will condense. There is a good description in "A Deepness in the Sky" from Vernor Vinge.
Free oxygen is extremely reactive and unless you have something that is generating it (i.e. plants) pretty soon it's going to disappear from atmosphere.
I've read its more like a million years for photons to finish their random walk through the photosphere and exit the sun.
How's this for far-fetched...
Astronomers observe a red giant being stripped of matter by a binary black hole companion. They predict within 10 years the red giant will completely break apart and fall into the black hole. Coincidentally, the axis of rotation of the black hole is somehow determined to be precisely aligned with our Sun. As a result, when the star falls in the black hole will release a colossal gamma ray burst (GRB)
What does the GRB do to the Sun? anyone's guess. maybe it blasts off the corona and several neptune-equivalent masses of plasma are thrown off into space. I'm sure this is an event you could run with in terms of outcomes, and not too many people would say "thats not what would happen" (except on this forum, hehe).
Oxygen would freeze out of the atmosphere into snow and over time bind itself to iron in the soil. You might be left with a snowy covering of CO2 and Nitrogen, however.
EDIT: not actually 'snow', but a crystallized solid form of oxygen.
A GRB which can harm the sun would probably blast away the upper parts of earth, too. This is not limited to the atmosphere.@CCWilson: A black hole can kick Earth away without significant tidal effects.
In liquid form, our atmosphere would be a layer of ~10-15m height, distributed over the oceans.
Interesting idea for a story. Something you're going to want to think about is the settlements themselves. We have no idea at this time how to make closed ecological systems, this is going to be a must if anyone is going to survive underground once the Earth's biosphere has failed. Consequently a long time to prepare (50-100+ years) might be needed for the R&D. Also you might want to give some thought as to the societal factors both physical and social e.g.
- What economic systems will be in place? Current models rely on growth but in such an underground vault set up steady-state systems with an emphasise on recycling may be better. Also how much private vs public ownership will be in place? It's all very well being free market until a monopoly on oxygen recycling forms.
- How good is the political set up? In the long run bad political systems tend to result in emigration and/or revolution. In a closed ecosystem the first is impractical and the latter catastrophic.
- How many people? It only takes a few thousand for sufficient genetic diversity but millions to adequately fulfil the specialist labour requirements of a technological civilisation.
- What nationalities/cultures and how will they clash? If the R&D and construction of these vaults is by economically developed countries how will less economically developed countries react? What will the social implications be for a minority group who are the few remaining survivors of an ethnicity/nationality/religion etc? What are the implications of a sudden, confined mixture of cultures (possibly violently incompatible)?
Hope this helps!
I've always found the social, economic, and political tensions/repurcussions of drastic shifts in technology to be the joi d'vivre of reading science fiction.
Kim Stanley Robinson has a great Mars series, (Red Mars, Green Mars, Blue Mars). As I recall there was some fairly good insight into closed-loop ecosystems and habitation, which they set up in the first novel (red mars).
One thought I have is that in such a scenario, it would be quite easy to justify imposing a totalitarian regime. First off, its a basic survival competition, everything is scarce, so the argument that there's no room to indulge personal fantasies or dreams, or that everyone needs to suffer hardship for the greater good, are hard to defeat. Second, the very nature of the infrastructurally-dependent society lends itself to totalizing power structures, e.g. the Recycling engineers guild, or whoever captures the power generators. Also, in a society that survives by adapting to scarcity, a natural ethic or ideology of minimizing consumption would emerge. Today we might evaluate a persons success by their nice home, or new car, etc. In that world, it might be more on how efficient you are in water usage, or calorie metabolization, or thrify in re-purposing broken tools, machines, etc.
For that, you might find literature on life in the Eastern bloc most informative. They necessarily adapted to living in a totalizing society that controlled all major industries, and quite often prided themselves on their thriftiness in getting on without consumer goods, or re-using re-building old discarded machines.
Ryan, I have been thinking along some of those lines. I believe that multiple underground cities would be built, each served by a nearby power plant, one or several by every nation or group of nations with the economic wherewithal. And the psychology of being on an eventually doomed planet, the physical, political, economic, and cultural adjustments to life in a bunker, the process of selecting who's to populate those cities - there's a lot of potential there. At some point I'll need to get together with people who will help keep the story on the straight and narrow with respect to scientific and technological plausibility.
Agreed!
The Mars Triology was quite good for that, it stands out for me as one of the few real explorers of new economic models.
It would also be physically easy to implement. Keeping a closed ecosystem going would require ubiquitous surveillance (tracking animal/plant/fungi/microorganism population numbers, interactions and diversity, monitoring the status of critical machinary, surrounding rock etc). Not only that but the ability to finely control the environment to alter any of these parameters. In such a system dissent could be easily detected and dealt with, there's no real way to form a resistance and a violent revolution in a confined closed system could be catastrophic.
However it's not the only way things may go and given the possibility (however slim) of violent revolution it might not go that way. A better system could be one of widespread consumer co-operative enterprises or direct public ownership.
Indeed there's lots of interesting scope for story. Just thinking about what the culture and psychology (not to mention technology) of the people entering the cities would be after generations of effort to build these things because the end of the world is coming (and only a few will survive) is an effort!
I'd imagine that a millennialist religious theocracy would work well in this situation. The end of the Sun is a sign from God. The other thing is that if it's obvious that everyone is going to die in the end, I think "rational" people would likely give up. It's the people that think that God will perform a miracle if we are all good, that are likely to keep going forward.
As far as the social setup, I think something military would work. Militaries deal with small closed social systems, and the number of people is small enough so that any sort of dissent would be quickly wiped out.
But we are in survival mode. One thing about a sudden population crash is that the economy is likely to be based on scavanging. One thing about a "cold earth" is that it's likely to leave a lot of technology in good shape. If you have a car that leave it out in normal temperatures, it will disintegrate in about a century. If you have a car and freeze it in liquid nitrogen temperatures for a thousand years, I'd imagine that it would be *possible* to have it working.
So I can imagine that "technology" would consist of being able to mining old machines and make them work, and I can imagine a religion growing up around this. You have "wizards" that know the secret methods of getting an engine from the surface and have it work rather than explode.
I'm not so convinced, I think the majority of people whether they are religious or not would want the human race to survive. I don't see why it would be rational to give up :confused: that sounds like one of those weird criticisms of atheists that they must have no hope without god.
Hmmm, the problem IMO with a military set up is that whilst it is good for undemocratic organisations that people voluntarily (or temporarily) join I think it's a bad way to run a society at large. Militarism generates a large amount of social tension and this would go further, almost Khakistocracy! It seems that the social set up has to be rigid enough to act quickly and decisively but flexible enough to adapt and satisfy the social need for freedom.
I don't really see that as working very well at all. I doubt the majority of modern equipment would survive in such conditions and if you don't have the expertise to fix and maintain them you're in trouble. Not only that but the knowledge to use them would have to be kept known by someone, you can't just rely on having it written down and try to get people to self-learn when you need it. I could go on but others have put it better.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 18 ·
